E30 Parts Compatibility To E21
danzuc76
Hi all, this is my first post so bear with me. Does anyone know if the E30 front seats would fit in an E21? Are the subframes the same, or are they interchangeable? Do the two models share any parts? Look forward to any responses. Dan.
whipsey
welcome dan i'd assume most of the parts would fit mate not 100% though
Virtually no parts are interchangeable and that includes the seats , sorry
whipsey
i stand corrected i thought the e21 had a similar floor pan
johnl320
Apart from M10/ M20 engine parts not a great deal
StuBeeDoo
Low_E30
My mates got a E21 323i, with a set of retrimmed E30 325i sport recaros waiting to go in, the e30 rear bench was an obvious no no, so he's stuck with the E21 bench, but the fronts are gonna need work too as the subframes need to be messed about with... from what he's told me it would have been easier if he had sourced a set if E21 recaros, & thats saying something as those are hard to come by!
E30 BMW 325i Cabriolet M-tech1 + Hardtop
W201 Mercedes 190E 2.5-16
W124 Mercedes E220 AMG Cabriolet + Hardtop
S124 Mercedes Estate AMG
C126 Mercedes 500 SEC
W210 Mercedes E55 AMG (2001 Facelift)
Jaguar XJR Supercharged (2002)
Andyboy
- Alpina Colada
An E46 is basically a fat E36 with a whole load of new problems, but the E30 and E21 are totally different. Nothing was swapped over and BMW changed everything apart from the roundels and the odd nut and bolt.
StuBeeDoo
johnono
but can anything be "upgraded" on an e21 from a e30 / e36? like suspension, calipers, steering rack?
engine and box is ok for swapping though, this ive seen first hand
StuBeeDoo
Andyboy
- Alpina Colada
Nope, nothing at all. They're totally different cars. You could put an E30 engine in but the e30 box is no good as it doesn't have a speedo drive. The E30 is a much better car so why fart about?johnono wrote:but can anything be "upgraded" on an e21 from a e30 / e36? like suspension, calipers, steering rack?
maxfield
There is an E21 with an S14 engine in on my calender??
maxfield wrote:There is an E21 with an S14 engine in on my calender??
At your age Maxfield the only calenders that interested me had pictures of young ladies taking it up the gary !
maxfield
That's on my other wallpacerpete wrote:At your age Maxfield the only calenders that interested me had pictures of young ladies taking it up the gary !
Andyboy
- Alpina Colada
Getrag 265 gearbox has provision for a speedo drive. The 265 is based on the four speed 262 which came out in 1968 on the 2500/2800.maxfield wrote:There is an E21 with an S14 engine in on my calender??
m-dtech
- Unapproved Trader caution
what are the diffs in comparison to e30 ??
e21Jason
Hi
Well a few parts swap apart from engines not much, e30 rear calipers are an upgrade for the e21 items, and the rear disks and shoes are same. The seats fit as mentioned, but require a lot of chopping to the seat frames.
All e21 run a small case diff, i have a e12 diff in mine as it is a meduim case item but dimensionally is the easyist to fit.
Jason
Jason
