I have an L reg 320se which i use as my daily commuter
It has only done 69000 fully documented miles and has always been owned by mature people - which means it has almost certainly never been lowered.The car sits very low though -
The problem is that with someone in the back i am getting the inside of the right rear arch scraping on the wheel - and particularly round corners
Nothing wrong with the shockers - they stay up rigid after a handbounce
Any ideas?
E36 - help on suspension
ivqii
- Regression is the way forward !
fozzymandeus
Have you checked your rear springs? They are very prone to cracking very near the bottom. Also check your suspension top mounts and rear trailing arm bushes. 70k ish is reasonable mileage for these to fail.
darkchild
Agree 100% with fozzymandeus here. The springs get covered in all kind of crap over the years and are well known for rotting, and eventually snapping, at the bottom.
ivqii
Many thanks for the input guys - sorry for the delay in replying
The car went through MOT with no fault 2 days before i posted the original post here
Shouldn't any of the above been picked up at MOT?
Ant
- Retired Team Member
broken springs should have failed , but they're not obvious unless you are aware of the issue on the model and go looking, which is not really "pukka" for a tester, all cars should be tested to the same criteria.
If its low enough to rub then something is defo amiss.
Email FTW
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
ivqii wrote:Many thanks for the input guys - sorry for the delay in replying
I've previously had my car pass an MOT only to find 2 broken springs a week later - as Ant said, it can be easily missed!
Taylor.
Mox3d
The rears almost always (like every one I've seen come in over the last year needing springs) break at the bottom just above the bottom loop of the spring. That bottom end of the rear springs sits in a well of the radius arm and sometimes can be fairly hard to see, certainly if youre not on the lookout for it. And it will not be visible or obvious at all if the wheels are on.
