E34 540i problems
maxfield
Post Tue May 29, 2007 7:43 pm
My dad removed the immobiliser from it now the fuel pump works sometimes and other times it doesn't, any help would be appreciated.
A wiring diagram would be nice too :)
Thanks,
Jamie
CraigG
Post Tue May 29, 2007 9:20 pm
why did he remove the immobiliser? that was just destened to run into running problems no? :P
Davenotouring
Post Tue May 29, 2007 9:22 pm
Here is a wiring diagram, the problem area is in red.
BMW 328i Cab - Daily Slag
Davenotouring
Post Tue May 29, 2007 9:23 pm
The wire from the sensors to the ECU is too thin also, check that out.
maxfield
Post Tue May 29, 2007 9:28 pm
It was an aftermarket immobiliser which was causing all sorts of problems.
Dave i think your problem is in your head :)
Davenotouring
Post Tue May 29, 2007 9:30 pm
You're not wrong there. :mad:
Theo
Post Tue May 29, 2007 9:37 pm
He's probably putting diesel in again Janice.
320Touring
Post Tue May 29, 2007 9:41 pm
surely dave, the pump needs a signal from the ECU to tell it tio initiate pumping....
amateur!
Max- likely that the Imobiliser is wired in some way to the ECU or pump and is stopping them working/sending correct signals!
maxfield
Post Tue May 29, 2007 9:43 pm
Theo325 wrote:He's probably putting diesel in again Janice.
Would still run on it, they're rather thirsty :o
Davenotouring
Post Tue May 29, 2007 9:44 pm
No, the pump is always activated. The ECU just tells the injectors when to open.
maxfield
Post Tue May 29, 2007 9:45 pm
Davenotouring wrote:No, the pump is always activated. The ECU just tells the injectors when to open.
The ECU on the 540i probably tells them to stay open all the time :D
CraigG
Post Tue May 29, 2007 10:17 pm
a common method for immobilizing a vehicle is to cut the feed to the pump, no fuel, no go. so if he has just removed an immobilizer, that problem should be staring him in the face, check all the wiring from where he removed the immob to the pump(ie physically trace the wire) pump should be fairly straight forward tho, a live feed from the battery (this is where the immobilizer should be spliced into..)
stuartgallafant
Post Wed May 30, 2007 7:29 pm
Stop f*cking around and call an auto electrician...
maxfield
Post Wed May 30, 2007 7:31 pm
stuartgallafant wrote:Stop f*cking around and call an auto electrician...
That is quite difficult in spain :)
stuartgallafant
Post Wed May 30, 2007 7:35 pm
You're in Spain???
Davenotouring
Post Wed May 30, 2007 7:56 pm
Oh yes, I forgot there are no auto electricians in Spain.
maxfield
Post Wed May 30, 2007 8:02 pm
stuartgallafant wrote:You're in Spain???
The car is :wink:
Not many English ones.
Davenotouring
Post Wed May 30, 2007 8:04 pm
You should get a Spanish one, learn to speak the language if you live there! Or get a translator!
maxfield
Post Wed May 30, 2007 8:05 pm
I don't live here my dad lives here and there.
I've learnt Spanish the last 2 years at school and hardly know nothing.
Davenotouring
Post Wed May 30, 2007 8:06 pm
El electricista
maxfield
Post Wed May 30, 2007 8:10 pm
The electrition
I learnt a bit i suppose.
Davenotouring
Post Wed May 30, 2007 8:15 pm
:wink:
Wish I spoke Spanish, I'd fly over and help you! haha!
maxfield
Post Wed May 30, 2007 8:48 pm
:lol:
The cars a turd!
Sounds nice tho :)
Davenotouring
Post Wed May 30, 2007 8:50 pm
Get a Haynes Manual!
maxfield
Post Wed May 30, 2007 8:55 pm
He said he's getting one before he goes back.
But help from here would also be nice :)
Davenotouring
Post Wed May 30, 2007 8:59 pm
You learnt Spanish for two years, but can't speak it at all?
Fu**ing school! Great!
maxfield
Post Wed May 30, 2007 9:01 pm
It certainly was :)
All we did was talk about the weekend.
Learned a bit :)
stuartgallafant
Post Thu May 31, 2007 1:27 pm
i went to Isla de Margarita for 2 weeks and learnt more spanish then, they you obviously learnt in 2 years!!!
**BANNED**
Post Thu May 31, 2007 4:36 pm
I reckon the problem is that the Spanish cannot speak maxfield....
maxfield
Post Thu May 31, 2007 4:42 pm
Maxfield speaks English :wink:
Looks like we should give Jock a call :D :D
stuartgallafant
Post Thu May 31, 2007 6:43 pm
daimlerman wrote:I reckon the problem is that the Spanish cannot speak maxfield....
:lol: :lol: :lol:
i like it daimlerman!!!
