316i compact
whiterhino
Post Fri May 18, 2007 9:07 pm
hello guys pondering on a deal for a blue 316i compact auto.80k full history straight body no rust.rip in back seat and broken parcel shelf.car drove lovely but was wandering if you guys know if there any good.its a 96n and has tons if horse sh?t underneath.its based on a farm.sadly not a ceccoto or a sport but ill be back.martgage comes first cheers.oh yeah i can have it for £2200
M3 cecotto ultimate driving machine
johnono
Post Sat May 19, 2007 9:49 pm
lol, not sure if this is worth writing :oops:
get it.
if you´re only after a reasonable runabout with a few mod cons and a stress free drive, get it.
the handling on mine is good, and i base that on very little... :cool: other than the fact that my previous held road well
the compact has the same rear end susp. wise as an E30, but lacks the stabiliser bar so it gets a bit twitchy over manhole covers,
inside is just like home from home really, its an E30 with e36 switches and instrument cluster! they are light, and even though a 1.6 can still shift. although you won´t be leaving anyone behind for long ;)
rear brakes are drums, front brakes are solid discs, the disc setup can be swapped for the generic e36 front assembaly to give you vented if you feel u need it.
the rear isnt such an easy task, and the trailing arms need to be swapped about for it to be wort the time taken.
M43b16 is a pretty strong engine, its got a timing chain, no belt so a tensioner change every 60k is good enough.
the shell and chassis are good, no jacking points to worry about and the door connectors are as solid as u like
2200 is a lot though, esp. for a 96´er. get one after the facelift at 97 if poss. they look alittle better
