e36 noise
nev325isport
OllieB
Could be the diff bush has perished?
I'm too scared to drift properly......
stuartgallafant
E36 has 2 diff bushes
is this at speed or at stand-still? if its at speed, is it worse when faster/slower, round corners, etc?
having a bit more info will help to determine the cause. I've known of a lot of E36's ot suffer extremely bad rust where the subframe bolts upto the chassis. so much so, that the floor pan had rusted through, and only 2 of 4 mounts for the subframe were actually holding it onto the chassis. £3500 was the estimated repair bill, needless to say, he scrapped the car!!
his complaints were clunking when changing gear (clutch activation) and hard cornering
eko
- Old timer
I recently sorted a similar thing on my mates E36 318is.
Turned out the diff mounting bolt had sheared off leaving part of the thread left in there.
Was a bastard to do without taking the diff out!
Symptom-let the clutch out and heavy thud from the back end.
If you dont have access to a ramp,lie down at the back of the car and get your mate to slowly jerk the car using the clutch,should be able to see whats giving
Andy325i
Pm sent
Andy
Andy
stuartgallafant
nev325isport
its the floor pan on this apparently needs reinforcing plates as the mounts have torn free. do you know any local bmw specialists that might want to do this job?eko wrote:I recently sorted a similar thing on my mates E36 318is.
Andy325i
Nev, Here are the plates I mentioned:
Both them pics are photoshopped, but is how it looks after fitting the compact back end this week
The front end will be soon
Andy
stuartgallafant wrote:any news?
by the way, Andy325i, those Contour 21's look awesome on your car mate
Andy
E30Mark
Sorry to go off topic for a moment, When you fitted the compact hubs, was the offset the same? Someone recently said you had to use E36 wheels, you couldn't use a E30 M3 wheel???ThanksBoth them pics are photoshopped, but is how it looks after fitting the compact back end this week
I have a set of contour 21's... (Well 3 off anyway!!) don't know if to sell them and source some 16" BBS for my project car...
PM for details
PM for details
nev325isport
stuartgallafant
i thought it might be this!! so more common in the E36 nowadays!nev325isport wrote:its the floor pan on this apparently needs reinforcing plates as the mounts have torn free. do you know any local bmw specialists that might want to do this job?eko wrote:I recently sorted a similar thing on my mates E36 318is.
my dealership wont even touch an E36 if it doesnt get the floorpan refitted, which comes at the cost of about £3000+ of your hard earned
so i dont know who would be willing to do this work for you
nev325isport
Andy325i
Yes, there isn't a lot there to start with, so hence BMW fitted these plates as standard to the M3 shells to take the extra abuse.nev325isport wrote:so these need to be welded to the original mounts then?
The compact use an E36 offset, so hence the hubs sit further out than an E30 M3 setup would, so using E30 M3 wheels on the compact arms would mean that they would sit further in than the E36 wheels so the track would be too narrow?
E36/E46/Compact/Z3 etc run less offset on the wheels than the rest of the 5 stud cars (E30 M3, E28, E34, E38 etc)
I have seen a couple of E36 cars running E34 BBS wheels, now that does look mean, but of course totally wrong offsets lol
How would we go about measuring the distance, hub to hub face for comparision as I guess this changes in relationship to where the suspension is sitting?
I hope this helps, if you need any more info just shout, hopefully it will be at a Dorset meet soon
Andy
stuartgallafant
