My "new" 323 convertible has unfortunately had tints put in.
Strange choice realy as the owner is not the bling type (middle aged, no big rims etc.).
Anyway, bottom line is I don't like thim. To me it don't look right!.
Thing is, whats the easiest way to remove the tints. Razor blade? Thinners? heating the glass and picking / peeling? I don't want to go to the point of replacement glass as I don't want to mess around with the comfort settings where the glass drops slightly to clear the hood as per coupes.
Anyone done anything similar. Any ideas?
Tint's removal!
Its not a 2 min job to remove tints but I found this the easiest way:
First you need to peel the film off which and be tricky and very annoying.
This will leave you with a window covered in glue. With advice from a chemical expert at my work, the best thing to remove the glue is Rain X as it contains a certain chemical and also use the back of a sponge to help break it up.
Its best to do one window at a time as you dont want to be driving around with a window covered in glue.
I had to do this on my Fiat Stilo (worst car ever) due to a crackdown by the police round my way and it does work.
<a><IMG></a>
Cheers steviec i had to take my tints off the front as police were threatening action, i pulled the tint off with ease but on drivers side window it left loads of glue on there and i still havent cleaned it off, so thanks for the tip.
Your on kuk yeh???
Your on kuk yeh???
nice will u be out this weekend??
Im hoping to have my diff fitted saturday so if all goes well and i get tax ill be out, but ill be taking it easy as my front wheel is pushed back and the wheel alignment is way out but wont stop me driving her lol.
- e30-unit-soldier
peal the film off and go down to the local hand car wash and ask them to wipe clean your windows with tar and glue remover! works a treat and probably charge you about 2 quid!
AND IT WORKSSteviec wrote:Its not a 2 min job to remove tints but I found this the easiest way:
Thanks for all the tips guys.
