E34 530i V8, Bought It, Well Happy, Passed MOT
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Mar 08, 2007 6:52 pm
Guys
Im gonna look at the above tomorrow with 116000 on the clock, with cream leather, aircon and OBC.
Its also a Auto
Anything i need to double check or look out for ??
thanks
Neil
320Touring
Post Thu Mar 08, 2007 6:53 pm
nickasil issues on the block
should have a 5 speed auto, make sure all the gears engage!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Mar 08, 2007 6:55 pm
whats nickasil?
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Mar 08, 2007 6:57 pm
forgot to mention its a 93 model
320Touring
Post Thu Mar 08, 2007 7:09 pm
Nikasil was the liners used for the block on the m60 engine.
my £140 730i v8 has rebuild reciepts under warrenty for this issue- £9500+
stuartgallafant
Post Thu Mar 08, 2007 7:28 pm
if it had nikasil, it would of been changed, or gone very wrong by now, so i cant imagine its anything to worry about
just make sure you know where as many petrol stations are as you can
cliffy, get me the chassis number and i'll search the computers at work to see what its had, etc...
320Touring
Post Thu Mar 08, 2007 7:35 pm
stuartgallafant wrote:just make sure you know where as many petrol stations are as you can
my 7 does 32 on the Mway at 70mph, and 15 :cry: round town!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Mar 08, 2007 8:24 pm
Stu i've got the number plate, is that any good??
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Mar 08, 2007 10:11 pm
if its running a bit lump, is it just a case of a good service, ie plugs, leads and filters?? Maybe even cleaning the ICV and air glow meter
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Mar 08, 2007 10:52 pm
anyone??
bigdek
Post Thu Mar 08, 2007 11:21 pm
a really lumpy idle was usually sign of the nikasil problem m8
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Mar 08, 2007 11:23 pm
The guy selling it recorns it just needs a good service, how lumpy we talking to think it would be nikasil??
Andyboy
Alpina Colada
Post Thu Mar 08, 2007 11:41 pm
Unless it's £500 I'd give that thing a swerve. Trouble with the V8 stuff is that it's not DIY fixable. There are still loads of Nikasil engines about - Nikasil was a Nickel-silicon coating used by Porsche on virtually all their engines and BMW on their boxer twins - coating the bores of an alloy block was cheaper than sleeving with steel sleeves. Running in was crucial - if it did too many short trips using the high suphur fuel around in the nineties, the coating would flake and the engine would gradually lose compression as the rings ate into the alloy bores. Jaguar had the same problem with their V8's but Porsche didn't because by the time the high sulphur fuels arrived, the 911's and 928's were all old cars and well run in.
The M62 units used Alusil as used on the V12. Alusil is not a coating - it's an extremely hard silicon alloy used for the whole block and the pistons are coated in cast iron and fitted with softer grade rings.
Any old Nikasil V8 that idles like a disgruntled hog is on the way out. Pay a couple of hundred quids and blast about in it before it shits itself.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Mar 08, 2007 11:43 pm
hmm wondering wether to steer clear, im only looking to give 300notes for it :?
Post Fri Mar 09, 2007 9:31 am
E34 530 V8s are pointless and sad, (at least a 540 while still fragile and sad is fast) an M30 535I is a better car in every way bar the nice V8 burble from the 530.
To summarise ,a £500 530 is a £1500 chocolate engine and £1500 margarine gearbox waiting to expire on an unfortunate victim ! :( The fact that the car runs poorly is a sure sign of council previous , zero maintenance and issues, don't do it !
On the other hand i have a very nice sterling silver 535 sport with black recaro leather, cruise, a/c and lots of other morsels that may be for sale ! :)
Andyboy
Alpina Colada
Post Fri Mar 09, 2007 9:41 am
cliffybabe wrote:hmm wondering wether to steer clear, im only looking to give 300notes for it :?
You can't go wrong at that price Clifford.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 09, 2007 12:27 pm
result stu has checked the car out and it was recalled for nikasil work, it had the uprated thermo stat and DME reprogramed so fingers crossed it should be cool :cool:
Mahmood
Post Fri Mar 09, 2007 1:31 pm
Dude, are you collecting cars?
bobafett
Post Fri Mar 09, 2007 1:45 pm
The lumpy running could be down to the diaphragm at the bulkhead end of the inlet manifold blown, causing inbalance inside the chamber and burning too much crankcase gas..Oil leaks from the upper timing cover gaskets to cylinder heads is common, snapped head bolts is another favourite so check out the oil on dipstick and cap aswell :!: . But for £300 notes, go on get it after checking out the above ......Good luck cliffy (not much crome on the 5 series E34's though). :D
What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
Andyboy
Alpina Colada
Post Fri Mar 09, 2007 2:26 pm
bobafett wrote:not much crome on the 5 series E34's though). :D
Very little, just a smattering around the side glass. ECP chrome arch kit methinks.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 09, 2007 3:30 pm
Well this aint got no chrome except for the grill, It has a option from factory for dechroming :cry:
bobafett
Post Fri Mar 09, 2007 5:41 pm
Ah bless !
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 09, 2007 9:09 pm
guys im well pleased picked her up tonight 300quid it pull slike a train, i think it just needs a real good service.
Theres a few little dent on her and a sratch but the inside is mint and the service history goes up to 114 and its now 118 and the last service stamp was in 19/6/05.
Im gonna get it MOT'd in the morning and give it a good bull up tomorrow
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 09, 2007 9:18 pm
Here's the pic fromt he add he had
Andyboy
Alpina Colada
Post Fri Mar 09, 2007 9:19 pm
Smooooooooooooooth. :cool:
tylerma
Post Fri Mar 09, 2007 9:21 pm
nice one Neil
what colour
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 09, 2007 9:30 pm
cheers guys
Malc, Im not sure which green it is Stu got me a print out from work which has the spec etc, Im sure there is a sticker underneath the bonnet ill check in the morning
tylerma
Post Fri Mar 09, 2007 9:32 pm
cliffybabe wrote:green
:eek:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 09, 2007 9:34 pm
Didnt u notice it was green??
tylerma
Post Fri Mar 09, 2007 9:38 pm
nah its a bit blurry
would have thought you would have had black
not a big fan of green cars
colour is bad luck
well done though mate
wouldnt mind a go too
to compare with the old mans 530i
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 09, 2007 9:53 pm
im gonna bring it to guildford on wed's if it passes the MOT
Its a nice green ill take some more pics tomorrow
dips346
London Meets Main Man
Post Fri Mar 09, 2007 9:55 pm
what have you DONE :roll:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 09, 2007 9:56 pm
dips346 wrote:what have you DONE :roll:
Y???
dips346
Post Fri Mar 09, 2007 9:57 pm
Y???
you brought a green tank
now i have to find another model for chrome
cliffybabe
Powered by Nelly
Powered by Nelly
yeah buts its a nice green tank and its bloody quick winkeye
