E36 320i missfire
Beemer-Boy-Dan
Post Wed Feb 14, 2007 10:30 pm
Hi, Can anyone help me please - I own a E36 320i SE, N Reg. I seem to have lack of power and the car is not accelerating and pulling like it should, it takes a long time for the revs to pick up. Personally I think there is a missfire somewhere, could anyone help me if they know anything else that it could be and why its happening?
Dan
Andyboy
Alpina Colada
Post Thu Feb 15, 2007 10:35 pm
Get it plugged in and the fault codes read - otherwise you'll just be guessing and bolting expensive bits to it. Crank sensor, cam sensor, throttle switch, air mass meter, sticky vanos unit..................
Post Thu Feb 15, 2007 10:36 pm
cracked coil packs?
Beemer-Boy-Dan
Post Thu Feb 15, 2007 10:59 pm
Hi thanks for the info i thought it could possibily be coil packs but i will get it checked, could it be the lambda sensor by any chance?
Andyboy
Alpina Colada
Post Fri Feb 16, 2007 12:01 am
Yep - but it could be anything!
My 320i has a weird idling problem showing up as a faulty throttle switch on the scanner - even though it's not. The voltage is fluctuating like a bastard so could be a dirty pin on the ECU connection.
Beemer-Boy-Dan
Post Fri Feb 16, 2007 4:53 pm
i just had it plugged in today and it came up saying its the air mass sensor. thanks for all ya info peeps.
Dan
