Advice from E34 owners please
gurj
Post Thu Feb 08, 2007 12:54 pm
Hi all. Im off to look at a 525i sport 1995 N plate tommorow. I do not know too much about these M50 engines so any info on what to look out for would be appreciated. any common places i should be looking for rust? Its done 165K with full service history, most of which is by BMW. Is this mileage a tad too much? Any info what so ever would be very benifitial to me. Thanks in advance.
ed325i
Post Thu Feb 08, 2007 1:17 pm
Hi, Start it from cold to see if the tappets are noisey. Check for rust on the doors and front wings and also round the number plate lights. Drive it and see if there is knocking from the back if there is the axle beam mounts will need to be replaced ask if they have been done. See if the air con works.
Is it a black one with 1/2 leather ?
Here is mine.
320Touring
Post Thu Feb 08, 2007 1:21 pm
Front suspension is worth a check- has upper and lower balljoints/arm, can be a bitch to replace
Check for fuel leaks too-esp near the diff.
gurj
Post Thu Feb 08, 2007 2:12 pm
ed325i wrote:Hi, Start it from cold to see if the tappets are noisey. Check for rust on the doors and front wings and also round the number plate lights. Drive it and see if there is knocking from the back if there is the axle beam mounts will need to be replaced ask if they have been done. See if the air con works.
Here is mine.
Hi mate thanks for the info. I will look out for the points suggested. Yes it's the black one with half leather. You know much about it?
bmpaul
Post Fri Feb 09, 2007 2:15 pm
also golden rule watch for the water pumps with plastic impellor, i had a e34 525i and when it went it was a bitch to bleed so check on its status
E39 530d M-sport- quite nippy
Conan
Post Sat Feb 10, 2007 4:14 pm
Do it! Best e34 after the M5 i reckon.
This is mine:
'91 Sterling Silver e30 320i SE
'96 Avus Blue e34 525i Sport
'92 Alpine White e30 318iS Touring
'86 Alpine White e28 M5 (008/187)
'02 Titan Silver e39 530d Sport Touring
'54 Cosmos Black e61 535d MSport Touring
'07 Sapphire Black e61 M5 Touring
gareth
Post Sat Feb 10, 2007 8:43 pm
looks like the kid next door likes yours conan!!!!
also watch for wandering at speed as they get through subframe bushes quite quickly. not a hard job for a good garage to do but keep £150 spare as it's time consuming.
rust areas around the fuel filler and rear arches were common while i was looking for a good one.
if you do get one, you need these: :D
http://www.e30zone.net/modules.php?name ... hlight=bbs
