E34 Help.....
BIGJO
Can anyone tell me why there would be power-steering fluid leaking from the passanger rear door? It seems to me that one of the pipes/cartridges are leaking. I have it booked in on Monday but need to know whether I need to get any parts from BMW...
I also need help with the steering on the E34. It seems that there is too much free-play in the steering. Any suggestions why & how to overcome the problem?
Any help will be much appreciated.
Regards, BJ.
Regards, BJ.
Jesus325iTouring
- Frog freak !
Can't be power steering fluid in the rear door mate,doesn't make sense,all pipe work etc is in engine bay,quite what is leaking out of your rear door is rather strangeBIGJO wrote:Can anyone tell me why there would be power-steering fluid leaking from the passanger rear door? It seems to me that one of the pipes/cartridges are leaking. I have it booked in on Monday but need to know whether I need to get any parts from BMW...
Regards, BJ.
BIGJO
Think the M5 has self adjusting suspension though fella. The fluid is red so am assuming it's LHM fluid. Just topped it up today as was on the low. I noticed the leak when the car was up on the ramp getting the tracking & balancing done.
Regards, BJ.
Regards, BJ.
Jesus325iTouring
- Frog freak !
Ah didn't realise it was an M5,was just thinking of the system on the 525 sat in my drive.BIGJO wrote:Think the M5 has self adjusting suspension though fella. The fluid is red so am assuming it's LHM fluid. Just topped it up today as was on the low. I noticed the leak when the car was up on the ramp getting the tracking & balancing done.
Regards, BJ.
In that case,my advise is about as good as a chocalate teapot
BIGJO
Thanks anyway fella...
BIGJO
ATF is what I meant..............
M5pilot
Follow the powersteering and try to find the leak. The PAS pump also supplies the rear SLS shocks so it could be one of the pipes going to the rear.
Finding the leak should not be a problem, fixing it however may well be as there is not alot of space.
The free play in the steering is a very worn steering box - you'll need to get it refurbed or buy a new one.
Sal
Sal
bimmaman
My old e34 was leaking power steering fluid from the rear - it had self levelling suspension, and one of the pipes had corroded so badly it had made a small hole. I think you have to use a special hydraulic fluid, not ATF, but I cant remeber what it was now... Used to buy it from GSF - about £8 a litre... I was having to buy about a litre a week!
Got a couple of quotes to fix it - around £1000..
. Needless to say, I sold the old barge instead!
I think you can adjust the steering box as well - there is an adjusting screw or something on top, I was gonna sort mine out, but never got around to it... Oh, and on the steering column under the dash is another big nut which sometimes need tightening, but again, I don't know any more than that! Check out http://www.bimmer.info/forum/index.php - its a really usefull e34 forum (mainly yanks, but very helpfull!)
Im stripping an E34 Tourer with self leveling suspension at the moment mate so if you need anything just pm me
M5pilot
Do not adjust the steering box, it will not self centre properly and will be horrible to drive.
Sal
Sal
BIGJO
Thanks for the help people. The plan is to get it up on the ramp & then to have a good butchers tomorrow morning. Once i've established where it's leaking from the next step is to get the bit(s) replaced.
I might need to take you up on the offer Dan. I just hope it's nothing major like Bimmaman experienced with his E34. The fluid is red & am not sure what it's called. My mate Fowler told me once before but can't remember now.
I'm a member on http://www.bimmer.info/forum/index.php I tend to use it now that I have an E34. Yes majority are Yankee's & some of them know their sh*t i'll tell you straight!
Sal, thanks for the help & i'll be calling you tomorrow as I promised...
Regards, BJ.
Regards, BJ.
cliffybabe
- Powered by Nelly
Bigjo red fluid is ATF fluid, Steering fluid /gear box fluid mate
Im sure the stuff your supposed to use in these systems is green, like the LHM fluid
cliffybabe
- Powered by Nelly
spot on like chefDanThe wrote:Im sure the stuff your supposed to use in these systems is green, like the LHM fluid
BIGJO
LHM fluid is what I first thought, but m-dtech said about it being ATF fluid. So I just went along with that. The garage has been topping it with the ATF fluid, which is now worrying! Thought it was all the same sh*t!
Looks like i'm in trouble, yet again
Regards, BJ.
Regards, BJ.
bimmaman
Just remembered! CHF 7.1 is what I had to use. It should say on the top of the reservoir though...
Ant
- Retired Team Member
should be LHM dude
ATF will ruin all the seals
almost defo a corroded pipe or union, check where the pipes are clipped to the floor in the wheelarch area
you can remove the SLS and go with 535i dampers, will need a non SLS PAS pump assy though dude
Email FTW
BIGJO
Where can I get LHM from? I didn't need to get any before but looks like I will now.
And who's moved my thread? For what purpose? Doesn't make any sense!
Regards, BJ.
Regards, BJ.
OK mate, just pm as and when.BIGJO wrote:I might need to take you up on the offer Dan.
Ive got a cracking tow bar if your interested
Heres a link
http://forum.performancebmwmag.com/viewtopic.php?t=4407
ste
Hi BEG JO. Sal's advice is spot on.
When I used to own your car with about 15k less miles on her she was long overdue a steering box then. Have you looked at how much they cost?
BIGJO
No mate, so why don't you tell me? I thought it was the steering rack. Why don't you enlighten me with the price of fixing the steering? Am assuming the previous owners didn't get the box fixed.........
Regards, BIG JO (get it right mate)
M5pilot
A few guys on the M5board got their boxes refurbed - go on there and do a search or ask. Cheaper than buying a new one.
Sal
Sal
stuartgallafant
BIGJO
Thanks Stu, I got some from Cliffords just down the road & was about £13.00 for a litre. Went to BMW to get a few parts for the M5 & enquired about the LHM fluid CHF11 & was about £11.00.
I think the leaks coming from these pipes that lead to the rear of the car with brake lines, fuel pipes etc. Need to get myself a fresh set of pipes as topping up the resorvoir is getting annoying. Think I might as well change them all as they will need changing at some point.
Regards, BJ.
Regards, BJ.
stuartgallafant
