520i
pah
Post Mon Apr 10, 2006 10:09 pm
Can anyone help me the first spark plug hole on my 520i keeps getting oil in it any ideas what is causing this . :(
wildeian
Post Mon Apr 10, 2006 10:14 pm
Had a similar prob on a 325, is the oil filler cap directly above it?
Could be leaking.
pah
Post Mon Apr 10, 2006 10:19 pm
No the oil filler cap is at the other end of the six cylinders . was told may be rocker cover gasket but nice man in the shop couldnt even find one in his book more help needed not sure what is causing it . thanks for your reply anyway.
wildeian
Post Mon Apr 10, 2006 10:24 pm
http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
Does this look about right?
If not, start a new search at realoem.com with your cars particulars.
pah
Post Mon Apr 10, 2006 10:52 pm
dont think thats the one but will try the site you gave me very many thanks for your help . Just spoken to someone who now says there are two types of engine for this car as it is an "h" reg 24 valve model.not sure how you tell which is which.
stranter
Post Tue Apr 11, 2006 10:16 am
H reg almost certainly means M20 12v IIRC and the oil leak into to the spark plug hole is going to be the rocker cover gasket. it's an easy DIY job, but make sure you use a proper BMW gasket and tighten the cover back up to the correct amount using a torque wrench.
Stewart
Edited to say: Here it is, you need number 3. Follow the instructions in the haynes manual (I am assuming it's in there).
pah
Post Tue Apr 11, 2006 12:42 pm
Thanks Stewart
m-dtech
Unapproved Trader caution
Post Wed Apr 12, 2006 1:49 am
yeah mate deff rocker cover gasket... was same on mine
pah
Post Thu Apr 13, 2006 12:58 pm
Thanks guys will sort that out then
Whats with Simon ?
