engine that never needs a timing belt change??
johnono
Post Tue Feb 28, 2006 11:12 pm
spoke to a fella today
said his engine(316 from a 98 e36) doesnԚ´t need to have the timing belt changed!
i nodded along but iԚ´m M20 trained and that made my brain itch
Widge
Post Tue Feb 28, 2006 11:17 pm
WTF!!!!
If it has a chain I can believe it, but if they can make belts that can be garanteed to last the life of the engine you would of thought everyone would use them, and retro fit them. If I was running th company that made these non wear out able belts I'd make them in every design there has ever been, make every other belt completly obselete.
ad318i
Post Tue Feb 28, 2006 11:20 pm
hell have a shock when it finally goes!!
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
johnono
Post Tue Feb 28, 2006 11:23 pm
i have a feeling he said "chain" :oops: oops
Widge
Post Tue Feb 28, 2006 11:28 pm
With modern high tensile steels and what has been learnt with the post claim era return to timing chains I can well believe it.
OllieB
Oops indeed.... :roll:
I'm too scared to drift properly......
johnono
Post Tue Feb 28, 2006 11:31 pm
so is it correct then, a timing chain is a permanent item?
what gets changed / seviced then?? just seems a bit too easy fellas
jonbuoy
Post Tue Feb 28, 2006 11:37 pm
Chain tensioner's get changed.
If you hear a rattly M3 it's usually the tensioner's need changing but they're a bastard of a job! :x
Timing chains are lifetime items for BMW engines in most cases, but tensioners and guides may have to be replaced.
johnono
Post Tue Feb 28, 2006 11:40 pm
cheers lads :cool:
Widge
Post Tue Feb 28, 2006 11:48 pm
Chains can and used to stretch which isn't really a problem as tensioners ( if they work) can take this up, but ask anyone who has had a classic Saab 900, they can get very noisey when stretched. They will still be no where near breaking, but unlike a belt the sound warns you to do somthing about it. The noise was the reason most manufacturers went to belts in the '80's and '90's, then realised chanins were a better idea :roll:
johnono
Post Tue Feb 28, 2006 11:50 pm
why dont people convert the m20 to run with a chain?
Post Tue Feb 28, 2006 11:51 pm
BMW only made two designs of engine with belts.
Unfortunately, these are the ones occupying the engine bays of most E30s.
johnono
Post Tue Feb 28, 2006 11:53 pm
cant the pullys / runners be adapted or converted to run with chains?
Widge
Post Tue Feb 28, 2006 11:58 pm
More effort than it's worth, only worth the effort if you know you are going to keep it for 25 years! You only have to change them a few times if you keep the car a while, and they aren't that expensive or difficult to change. I can do a belt in 4 hours and they only cost Ԛ£15 ish
Turbo-Brown
Boost Junkie
Post Wed Mar 01, 2006 8:07 am
The problem with converting say an M20 to chain drive is that the timing belt cover is designed to keep big bits of crap out, and the oil in the engine, whereas chains need to keep everything out except the oil.
sixualhealing
Post Thu Mar 02, 2006 11:59 pm
My one and only BMW was 20+ yrs ago.
A 1600, but that had a timing chain IIRC. Got a bit noisy, so I talked to BMWspares in Kent, ( I knew I couldn't afford main agent prices). He advised me to check the cylinder head for cam wear. They didn't run any bearings just the cam in plain ally, :roll: , but I found the actual cam was worn as well as the head. Too much for the chain tensioner to deal with. Too much expence for my wallet as well :wink: .
Sold it on cheap. 5 mths later the bill asked me if I had abandoned it in a carpark. No.
Image[/img]
Dan318-is
Post Fri Mar 03, 2006 12:02 am
It would be impossible to convert an m20; the tensioner for the chain on most e30 lumps rely on oil pressure you see
kam-325i
Post Fri Mar 03, 2006 12:46 am
And imagine trying to get the timiming right......
georob
Post Fri Mar 03, 2006 12:48 am
so how often should the 320 lump timing belt/ chain get changed?
OllieB
Post Fri Mar 03, 2006 12:52 am
I think the belt should be change every 60k or so geez....
Not that sure though, one of the technical geeks on here will surely tell you to the nearest .0002 of a mile.... :wink:
Widge
Post Fri Mar 03, 2006 9:06 am
40,000 miles or 2 years, whichever is first.
FlappySocks
Post Fri Mar 03, 2006 9:14 am
Why do car manufactures use knicker elastic to hold their engines together instead of chains? Is it to save money?
Stuart
Widge
Post Fri Mar 03, 2006 10:03 am
Nope it's because it's far quieter so they didn't have to spend so much time and research on sound proofing etc. But now they have realised customers resent having to forkout for regular like a timing belt and they snap so they fit chans and beef up the surrounding covers etc and new chains run pretty quiet anyway. Cheap compainies still fit belts though cos they are cheaper.
