Hand car paint
I have an e46 hard top which needs painting and was thinking of painting it by hand as opposed to an expensive spray job but cant seem to find which type to use, so can anyone advise me please ?
Gloss black.
Gloss black.
We had another team member once who had a preference for Dulux.
I once painted my Viva HA in blue Dulux with our kid after a load of Stella`s from bright red to mid blue.............it lasted the winter with no signs of coming off !!!Brianmoooore wrote: ↑Sat Aug 08, 2020 3:46 pmWe had another team member once who had a preference for Dulux.
But on a serious note, I think this is possible, the top only goes on when the clocks go back and I only see the thing in the dark and if it is that bad then next year we will look again.
With a bloody good brush I would like to give it go ................
steve_k
well having painted a few cars by hand myself over the years it is very possible to get a dam good finish if you take you time & dont mind wet sanding between coats.
also dont use a brush use some small gloss foam rollers (4" in length) as they give a better spread of the paint.
flybynite
Funny you should mention that but the one and only thing I painted by brush was a Viva Van
If you insist on not spraying it I would get something that is meant for the job like coach paint and as Steve said above use a well soaked gloss roller.
Can't help thinking a couple of rattle cans would make a better job though especially on a nice warm day?
How about this product ?steve_k wrote: ↑Sat Aug 08, 2020 6:11 pmwell having painted a few cars by hand myself over the years it is very possible to get a dam good finish if you take you time & dont mind wet sanding between coats.
https://www.ebay.co.uk/itm/1L-Gloss-Bla ... 2918094910
steve_k
that looks like it would be up to the job,martauto wrote: ↑Sun Aug 09, 2020 7:00 pmHow about this product ?steve_k wrote: ↑Sat Aug 08, 2020 6:11 pmwell having painted a few cars by hand myself over the years it is very possible to get a dam good finish if you take you time & dont mind wet sanding between coats.
yes it will need to be thinned but not too much, between each coat give it a light wet sanding & build up the coats, i'd say about 4 or 5 should do it.
Satan
Get some vinyl wrap from eBay and wrap it.
Cloggy Saint
flybynite
I don't know about that, getting vinyl to go round the compound curve of an E46 hard top, not the easiest as it would need to be done in one piece.Cloggy Saint wrote: ↑Tue Aug 11, 2020 12:09 pmThis would be a much better option, I can't imagine painting it with a brush/roller would ever look good.
Could end up with more bubbles than a fairy liquid factory
I'd rattle can plasti-dip it matt black, no harm done. When yo want to change it or spray it properly just peel it off
Satan
Can't imagine it costing much for a pro to do it as you use a heat gun, redid my handles on my Legacy and they came out okay, I know they are small in comparison........flybynite wrote: ↑Tue Aug 11, 2020 12:45 pmI don't know about that, getting vinyl to go round the compound curve of an E46 hard top, not the easiest as it would need to be done in one piece.Cloggy Saint wrote: ↑Tue Aug 11, 2020 12:09 pmThis would be a much better option, I can't imagine painting it with a brush/roller would ever look good.
Rust-oleum is reported to give excellent results, either brushed or rolled on.
Satan
Or go "Olde Skool" and get some propah vinyl..............
miniblob
Seen some good guides to painting online that go through all the steps & materials - seen some good results from just rattle cans (supposedly).
Never actually got round to trying it though.
Although I did paint parts of an old mini back together with hammerite once - hammer finish, 'cos I knew I'd never get it smooth and then it looked intentional!!!
327 Touring with bass!!!
Andyboy
- Alpina Colada
How to make a valuable E46 hardtop next to worthless.
F*cking bodgers. It'll cost 200 quid to paint it properly for Christs sake.
flybynite
I was quoted @£550-£650 to have it painted in the correct car colour but now I have no job its a no brainer !!
I was just exploring different ideas thats all, and if I get a couple of really good days , then it will get some satin black on until spring time when I may be in a better possition finance wise.
Satan
Put something on the hard top that can easily be removed.......
