E34 front doors question (for 525iX)
d1mkaz
Post Mon Mar 20, 2017 11:02 am
I am thinking of replacing both front doors instead of repairing rust as it is still possible to find decent ones for E34, I was browsing in-net in search of compatibility of E34's doors by year and by model, as far as I understood the doors from all models are the same there is a bit of difference between doors of E34's made before 91 and after 91. So I found a pair and asked about the year and model of the E34 they are off but when checking the RealOEM I found out that id nrs. of those differ from iX, example:
94 530i DOOR FRONT RIGHT 41518138006 DOOR FRONT LEFT 41518138005
94 525iX DOOR FRONT RIGHT 41518138004 DOOR FRONT LEFT 41518138003
It is only one last digit but now I am not sure if they actually the same, any ideas?
Thank you
Post Mon Mar 20, 2017 1:11 pm
Not sure but the locking mechanisms are different and fit different between early and late, holes are in different positions on the door
d1mkaz
Post Mon Mar 20, 2017 1:32 pm
DanThe wrote:Not sure but the locking mechanisms are different and fit different between early and late, holes are in different positions on the door
Thank you, do you mean early - before 91 and late - after 91? I checked the same year E34 530i saloon and E34 525iX and wonder if someone can advise if 1 digit at the end of OEM number can be significant difference?
d1mkaz
Post Tue Mar 21, 2017 4:34 pm
Sorry my fault here, somehow I checked US spec nrs here:
Nrs for Europe spec cars (RHD) are the same, so front doors are the same on saloons and estates.
Again sorry for confusion
