Epic fail. Help!
Post Thu Jun 16, 2016 11:35 pm
Basically I broke the door handle of a E64 6 Series.
What I wanted to ask is where you see the break on the handle, where does it go into without taking the door card first.
Because I wanted to know wether I would have to buy a handle mechanism as well.
Ignore the horrible wrapping
Post Fri Jun 17, 2016 11:06 am
Looks like you can just buy the handle Mo. Going on a 2006 model:
http://www.realoem.com/bmw/en/showparts ... Id=41_1582
About £30-£40 for a primed one (RH = 51216961444). All you gotta do is have it rewrapped.
P.S These look so much better in silver than white!!!!! 8O
Post Fri Jun 17, 2016 12:59 pm
Yeah its looking like it hopefully
You should see the epic skillz when this wrap was done :eek:
Its pearl white with a pink shimmer.
Post Fri Jun 17, 2016 10:37 pm
Blitz wrote: Its pearl white with a pink shimmer.
Suits you down to the ground then.
:wink:
ross_jsy
Post Fri Jun 17, 2016 10:43 pm
Pearl white with a pink shimmer. This was broken in a dogging incident, wasn't it :)
