E32 750i engines
satan16v
Post Sat Jun 04, 2016 12:36 pm
Hey chaps,
I'm on the look out for an E32 and have come across a pretty solid V12.
The seller has mentioned that the engine needs the throttle bodies cleaned to run properly.
Is this a known fault with that engine? Or is it likely to be something catastrophic, being passed off as a simple fix?
I'm not very tech'd with the bigger engines.
Are there any problem areas that I should stay away from with the V12?
Thanks in advance
E30 325i - In progress
E53 X5 4.6is - SOLD
E46 320d Sport Tourer - SOLD
E36 M3 - SOLD
E34 535I Sport - SOLD
alpina123
Post Sat Jun 04, 2016 12:45 pm
Common problem they are fly by wire not cable, either be Bosch or Siemens but it's likely they will need replacing rather than cleaning
Post Wed Jun 08, 2016 11:42 am
I am guessing the A/C just needs a regas / fuse :(
Andyboy
Alpina Colada
Post Thu Jun 09, 2016 7:37 pm
An old E32 750i with problems? How fast can you run? This was BMW's first attempt at electronic FBW throttles and they were a lot of aggro.
