I'm going to change the drive belts on my M54 shortly and am going to change the tensioners while I'm at it. I have done a bit of research and found that there are two types of tensioner, mechanical and hydraulic. I have read that either type can be fitted and that the mechanical ones are more reliable. So, should I just get the mechanical ones and fit them or should I fit what is currently fitted?
At the moment I have no idea which type mine has, I've had a quick look without success, I need to take a few bits off to be able to see but I won't be able to do that until the weekend.
Also is there anything else worth changing on the front of the engine while I'm at?
M54 Drive Belt Tensioners
While it's all out, maybe a water pump and fan clutch? Preventative maintenance and all that.....
clarko74
Yeah, I was half thinking it might be worth doing the water pump. It has an electric fan so I won't need a fan clutch.
Managed to get outside for a look. It appears I have a hydraulic one for the main belt and mechanical one for the smaller one:
Look at the state of that main belt! I'm concerned about driving it anywhere now I've seen that.
clarko74
