318i Auto woes.perfect car with new MOT throws in towel.
povertyspec
Post Fri Aug 28, 2015 10:44 am
got a 1999 318i touring, mint , loaded,all toys working,new tires,new mot,strong engine but.....the auto box isnt getting much power from the engine.junctions are hairy,but up at 30mph plus its fine. i have narrowed it down (maybe) to the torque converter. manual selection no better.if the seals go and pressure drops is it the end?. ecu ok i think and ABS, ACS lights out, wheel speeds sensors not checked tho.any common faults that cause the auto box to play up.
its really far too good to scrap but i might have to think long and hard about changing a major part.:-)
Andyboy
Alpina Colada
Post Tue Sep 01, 2015 7:11 pm
Could be the idle control valve on the throttle body. This is ASC controlled and when they go tits up the engine bogs down and has bugger all power.
povertyspec
Post Wed Sep 16, 2015 11:09 am
wouldn this show up as a fault on the diagnostics thingy?
Andyboy
Alpina Colada
Post Thu Sep 17, 2015 7:10 pm
No.
Post Thu Sep 17, 2015 7:24 pm
As its Bosch management there could be 20 faults that the ECU doesn't know about
Andyboy
Alpina Colada
Post Fri Sep 18, 2015 10:56 pm
You'd have as much luck code reading a Morris Oxford as an E36.
