1 series warning light question
E30_KIID
Post Sun Aug 02, 2015 9:21 pm
I'm off to view a one series tomorrow for a friend, and his pre warned me that in the advert it states a warning light is on. Apparently it's for ;
"DSC AND DTC DRIVING STABILITY CONTROL SYSTEMS, INCLUDING DRIVE OFF ASSISTANT, AND THE RUN FLAT INDICATOR HAVE FAILED".
I'm no mechanic so is it worth having a look at? Or shall he walk away? I'm just viewing the car as it needs some attention to the paint. Thanks in advance!
Vintage BMWs are an addiction.
sweep
Post Sun Aug 02, 2015 9:26 pm
Walk away.
E30_KIID
Post Sun Aug 02, 2015 9:46 pm
That bad? I thought it would just be a problem from a tyre change. Maybe going from run flats to normal tyres, thank fook I asked!
maxfield
Post Sun Aug 02, 2015 10:07 pm
E30_KIID wrote:That bad? I thought it would just be a problem from a tyre change. Maybe going from run flats to normal tyres, thank fook I asked!
The car doesn't know if it's got run flats fitted or not.
It could be an ABS fault. As the run flat monitoring system is done via the ABS/DSC, obviously when a tyre is flat it's rolling radius is different.
vytas85
Post Mon Aug 03, 2015 1:30 pm
or just try reset it's about 2min job.
Niko_p
Post Mon Aug 03, 2015 7:11 pm
I had a DSC warning light come up on my dash 3 days into owning a 130i. I thought it would just be a sensor so took it BMW to be diagnosed.
£150 later - I was presented with a £2000 bill as it was determined the DSC unit had failed, a common fault with one series.
I ended up getting a reconditioned unit and having installed via an independent at a cost of £650.
So I would walk away, or buy and take it somewhere to get fixed but bring money.
Andyboy
Alpina Colada
Post Thu Aug 06, 2015 7:10 am
Whilst 6 cyl 1 Series and E90 stuff has the £2000 ABS block, 4 cyl ones are under 200 quid.
