Bad time for engines at work...
P_VIDDY
Post Sun Feb 15, 2015 10:22 am
We currently have 9 engines waiting to be rebuilt/replaced. What is going on!
Mini Cooper with snapped camshaft pulley bolt...
X5 3.0d with melted piston
Passat with a slight issue on one cylinder... Small amount of debris in sump haha (amazingly still runs on 3 cylinders)...
X3 3.0d with snapped chain and lots of damage (missed a few oil services)
Old school mini having full rebuild due to oil leaks...
Not currently got photos of the following but we also have...
E46 320d with a snapped crank!!!!
Anothet X5 3.0d with a melted piston
E46 m3 with cracked head
E91 320d that has injested a swirl flap
Busy times!!!!
Andyboy
Alpina Colada
Post Sun Feb 15, 2015 10:35 am
I've got a complete 320d unit here - would solve your various issues!
P_VIDDY
Post Sun Feb 15, 2015 10:37 am
FAB already sorted me out. Thanks
Post Sat Feb 21, 2015 6:45 pm
.... and there I was planning on bringing my E38 down :P
Bristol_Jer
Post Sat Feb 21, 2015 7:03 pm
What causes the melted pistons on the x5's?
P_VIDDY
Post Sat Feb 21, 2015 7:08 pm
Time for a new engine imy? Haha
To be honest I don't know. I suspect faulty injector. Both are on cylinder 1 but I suspect that is coincidental.
P_VIDDY
Post Sat Feb 21, 2015 7:10 pm
I have however got to the bottom of the camshaft bolt snapping. Rebuilt the engine and when I tried to time it up exhaust camshaft was locked solid. Traced it to a faulty vac pump (runs off cam) that has collapsed and locked solid!!!! Expensive break that was
Post Sat Feb 21, 2015 7:11 pm
Haha, not new engine. Just got a hard starting problem at the moment that needs looking at :)
P_VIDDY
Post Sat Feb 21, 2015 7:18 pm
Sounds fu@"ed. that's number 10 on the list a˜‰a‘a
Post Sat Feb 21, 2015 7:20 pm
irish320i
Post Mon Feb 23, 2015 10:42 pm
melted piston like that normally caused by injector problems, what happened the passat leg outa bed? , we had a e46 320d a little while ago with a snapped crank, was previously flood damaged was running fine went for test and bang !!! just short of writing it of
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
Post Mon Feb 23, 2015 10:58 pm
My dad had a brand new Passat turbodiesel company car that managed around 14,000 miles without any sign of problems before it put a rod through the side of the block while he was going up a hill.
VW took the car back for examination and put a complete replacement new engine in.
irish320i
Post Mon Feb 23, 2015 11:04 pm
its crazy people here will do anything to avoid the 2.0 pd over the oil pump issues but will be overjoyed to find a beautiful 1.9 that will self destruct at any minute 8O
Al
P_VIDDY
Post Tue Feb 24, 2015 6:37 am
Most engines have there problems. It's just a case of how common
Andyboy
Alpina Colada
Post Tue Feb 24, 2015 9:41 am
Only certain engine codes on the 1.9PD have con rod issues.
If anyone wants a good M47N 150, there's one in the 'shop here.
Ianb
Post Tue Feb 24, 2015 9:42 am
The most common problem I've seen ( and been victim of ) is the Audi 2.0 td lump that was in my 57 reg A4 Special Edition - The famous oil pump issue. I still have the oil pump drive approx 5mm allen key that rounds off and also rounds the socket in the balance shaft assembly - This is what happens when Bloody Bean Counters are running the show and think they can save a tenner per car vs the thousands this costs us poor punters. Their loss though as I will never ever buy another Audi in my life.
