E34 dual sunroof help
Topblag
Post Sat Apr 26, 2014 10:37 pm
I'm fixing up a 1995 525ix tourer.
When I got it, the sunroofs didn't budge and there was a noisy rattle from the front when the sunroof motor was activated. I assumed it was the gears not connecting properly with the front panel. So, removed the clutch from it, stuck in an Allen key and the same result. Today I swapped out the front motor for a known working one and got the same result. The teeth on the original motor were worn down and one was snapped off.
Next I cleaned and regreased the 'worm' cables and then tried again with the Allan key, I managed to get the front sunroof to tilt up but no sliding. I greased the runners and the panel whilst it was raised.
Next I tried to move the cables manually, using a screwdriver and being careful not to bend the metal cable which the gear grips onto. They would both move only so far. I'm concluding the cables are seized somewhere.
The rear roof works from the motor.
Any assistance would be appreciated, I have a full tray which worked fine, with the corresponding motors as a spare, just don't want to have to change it all !
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Topblag
Post Sun Apr 27, 2014 9:49 pm
Bump
snakebrain
Post Sun Apr 27, 2014 10:00 pm
I would just leave it well alone in a closed position... :D
Luis325
Post Mon Apr 28, 2014 3:23 pm
Hey Topblag i have been trying to reach you for a long time.
Shoot me an email to see if you shipped out the mapllight.
