Ok folks, so I'm about to sell my 328 and downgrade to an 318is, not ideal I know, but needs must when I'm suddenly doing 500 miles per week.
The car I'm picking up is my mates, and currently off road due to failing the MOT on the metal brake lines being corroded (apparently common problem). I've taken a ganders on Real OEM but those drawing make little sense to me. Anyone provide with with some indications as to which bits I need and a suggestion as to the best placer (ie Euro's BMW GSF etc)
E36 318is brake lines
robbo86
Rear brake lines? If so its a tank down job, not fun!!
robbo86
Not sure yet, but probably knowing my luck... joy!
Duke137
LPG the 328i, job done
robbo86
Bit more too it then that Duke... Plus I cant afford to LPG it!
Wait until you get a quote for fixing the brake lines!
robbo86
Wonderful. Not what I wanted to hear either :S
To do the job properly, it's a tank out job, but there's nothing to stop you re routing them, as long as they're fixed securely.
Few feet of cunifer tube, female and male ends, and a decent flaring tool (i.e. NOT a cheap multi pipe size one) and the jobs easy enough. You don't have to replace the whole of the lines. Cut the pies under the car and join old to new with a single flare and double flare, plus a male and a female end.
robbo86
Cheers Brian, decided against the car after my girlfriends old man ramped it and took a look.
Gotta find something cheap and economical now!
