Is the inlet manifold off an e36 323i the same as the one off an e36 325i ?
Will the throttle body swap over from the 328i manifold straight on to the manifold of the 323 & 325i ?
thanks for any advice
manifold// throttle body question.
leeparkes
Manifold is different, E36 325i is the better one you want.
Not sure on the TB
Not sure on the TB
si911t
ok thanksleeparkes wrote:Manifold is different, E36 325i is the better one you want.
Not sure on the TB
I made a mistake then, as I bought one off eBay which was listed as 2.5 323i thinking they would be same .
should have asked the question before I pressed buy it now !
steve_k
The e36 323 is a 2.5 but as Lee says the manifold is different (same as the 328 one) you want the manifold & tb of the 325i.
si911t
Luckily ebay seller was a gent and agreedto refund before he sent out the manifold.steve_k wrote:The e36 323 is a 2.5 but as Lee says the manifold is different (same as the 328 one) you want the manifold & tb of the 325i.
Thanks. you guys saved me bit of an ass ache
steve_k
Glad you got it sortedsi911t wrote:Luckily ebay seller was a gent and agreedto refund before he sent out the manifold.steve_k wrote:The e36 323 is a 2.5 but as Lee says the manifold is different (same as the 328 one) you want the manifold & tb of the 325i.
