E34 M50 running dramas
Post Sat Apr 27, 2013 8:25 pm
See post 5
Post Sat Apr 27, 2013 9:09 pm
Both large cables go on the outer large stud. Have you fitted one on the outer and one on the inner?
Post Sat Apr 27, 2013 9:26 pm
I fitted both large cables outer and inner.
Post Sat Apr 27, 2013 9:34 pm
My fault Im a numpty I see where I went wrong. Going to connect it properly tomorrow.
Thank you
Post Sun Apr 28, 2013 12:25 am
You are using the entire output from your alternator to continuously run the starter motor!
Post Sun Apr 28, 2013 5:19 pm
Starter is fine now. Now I have a major air leak or a dodgy sensor. it idles at 1K RPM and when you apply throttle is kangeroos up and down. Plus when your driving and apply throttle theres a big delay and a violent lurch.
I've checked all the hoses and everything is connected.
Post Sun Apr 28, 2013 7:39 pm
TPS and ICV connectors on right way around?
Post Sun Apr 28, 2013 8:20 pm
E30BeemerLad wrote:TPS and ICV connectors on right way around?
You hero BeemerLad. Its fixed. Next time I should lable wires. :D
Post Sun Apr 28, 2013 10:08 pm
Was Lisa 'helping' ? :)
Post Tue Apr 30, 2013 6:54 pm
I wish
