330ci gear box oil change questions. --?
mcbonio
Post Fri Apr 12, 2013 9:25 am
My 330ci sport autobox seems a little sluggish at times, it's done 100k but still changes smoothly, just a little slower than it used to.
Would an oil change quicken things up?
There's a big sticker on the sump pan that says lifetime oil - no oil change. Am I likely to introduce problems if I change the oil?
What oil can I put in there and what capacity is the sump?
Post Fri Apr 12, 2013 7:10 pm
Not changing the oil is what shags these..
I believe BMW have since changed their "lifetime" oil policy to 100,000 mile intervals.
Still to long for me, 50,000 is when my autobox oil/filter gets changed
Basically, you need fully synthetic ATF, a new filter and a sump gasket, 6-7 litres usually
mcbonio
Post Thu Apr 18, 2013 8:10 pm
Any idea what gearbox oil this should be?
mcbonio
Post Thu Apr 18, 2013 8:42 pm
alpina123
Post Wed May 08, 2013 8:57 pm
yeah you can only get it from bmw I think its very dear
Post Wed May 08, 2013 9:09 pm
Nope you can get the correct stuff from ECP - it is expensive though - between £7 - £10 per litre depending what discount you can get.
You need to know what box is actually fitted to your car first though.
mcbonio
Post Thu May 09, 2013 5:18 pm
Job done guys,
The oil required for the A5S 325Z (ZF 5HP-19) gearbox is 'LT 71141' Esso, Shell and Mobil all make it, about £9.50 - £10.50 per liter.
It's done and shifting like a new gearbox.!
