I have spent the last 20 mins poking the drivers side with various bits of wire to no avail.
There appears to be 2 sets of wires going to it as well
Car is a 52 plate 325i SE
Ta in advance
Normally the above procedure is when both jets are blocked.sag wrote:Normally were the washer pump goes there is rubber grommit which has a filter ,which tends to get blocked up. I'll advise on removing the washer pump and clearing the rubbish from the rubber grommet. Also drain the tank and put fresh water and screen wash at the same time
Same. Amazing how much black gunk has come out of some before. It usually works better blowing through the jets rather than through the back end, but it's worth going both ways, along with having a poke with some wire.DanThe wrote:They usually get blocked through lack of screen wash additive in the washer bottle, fungus/algae grows and then gets trapped in the valves. Never failed to unblock one with 150psi yet
