e36 damp footwells
thecode
Noticed all the windows on my e36 where full of condensation, noticed the front drivers and passenger carpets are damp/wet any ideas to what is causing it.
thecode
how would i tell ?diable wrote:Sunroof?
lamby
have a mate hose it while your inside and see if it runs inby the floor
capnmchl
Having had many a car with a water leak, I can tell you the only solution is to strip the interior. Carpets are plastic backed, and once moisture gets behind them, it sits there festering away.
Stripping it out also helps you find the leak. As above though, the most likely culprit is a leaky sunroof drain.
