chaps, for those in the know. what spec as standard should a m535i be?
dog leg box etc etc
also should is say sport or similar on the log book, the same as e30 sport?
cheers for any advice, much appriciated
m535i e28
staley_turbo
It will say m535i on the log book,
They should have a diff, and bilstien shocks. They came in an auto as well i think.
snakebrain
Dog-leg box isn't standard. Did come in auto or manual. Log book will confirm the model, or take the VIN to a BMW dealer and they can get you an original build spec sheet so you can see how many morsels it's lost over the years.
Rich320I
cheers lads, iv been offered one it needs work body wise, but the service history etc are pretty good. im going to have a look at the weekend, so cheers for the info much appreciated
ANDY325TOURING
An E28 thats requires body work? surely not? good luck with it, they are just a big E30 really the 3.5 M30 gives plenty....
staley_turbo
Id say there probably worse for rot than the e30.
Rich320I
oooh yeah, might have noticed iv mentioned before i used to be into mk2 escorts and other old fords. so rot is something im used to, i could only have a look the other day in the relative dark (hence going back for a proper look tomorrow)
but the sills need work, boot and theres a suspicious lumpy area by the rear screen which i suspect is a wonderful mixture of P40 or similar!
thanks again for the advice, if i go for it il report back
snakebrain
Watch out for rot in the floor round the subframe mounts just inside the rear end of the sill. Much more hassle than a simple sill repair..Rich320I wrote:but the sills need work
Rich320I
cheers for the pointers, lads unfortunately was way worse than the chap made out, the complete area under the rear screen had gone through. shame but one of those things
