e46 help please
pukar
Post Mon Sep 24, 2012 11:19 pm
my mate has an e46 that is burning/using a lot of oil up. it is an 03 330ci sport. there is no oil on the driveway, and occas a bit of smoke from the engine bay on starting.....any ideas?
e30den
Post Mon Sep 24, 2012 11:25 pm
Crankcase breather valve may need changing
hth
mcbonio
Post Mon Sep 24, 2012 11:31 pm
Every e46 I've ever owned has had plastic paneling underneath the car which usually catches oil drops. The sump has a little door on the plastic paneling to access the sump nut. You'd have to open it from below and have a look to see if its collected any oil.
If there is smoke in engine bay, then you could have a leaking rocker cover gasket which could be dripping oil onto the exhaust manifold. I've never seen a leaking rocker cover gasket leak that much to worry about the oil level.
30 seconds under the bonnet should verify either of these possibilities.
Post Tue Sep 25, 2012 12:07 am
it's normal for the 330 to use oil 8O
pukar
Post Wed Sep 26, 2012 12:14 pm
thanks for the help guys, i will pass that on! 8) 8) 8) 8)
Post Wed Sep 26, 2012 6:37 pm
e30topless wrote:it's normal for the 330 to use oil 8O
apparently 0.5 - 1l of oil per 1000 miles consumption isnt unusual for these engines 8O
dowot
Post Wed Sep 26, 2012 8:10 pm
about 1 litre for 800 miles in mine........... no leaks/ smoke and a new ccv. :(
shadrack
Post Wed Sep 26, 2012 9:11 pm
i had one also 1ltr oil per 1000 miles so was costing fortune in oil, so switched to some £12 per 5ltr same grade and it stopped using it!
Mitchellman
Post Thu Oct 11, 2012 10:46 pm
Yes have owned 3 of these though usually high milers use th oil. My current 330ci uses hardly any. N fact it has not moved for the 3000 miles I have had the car.
