auto gearbox oil
whiterhino
as above really.is this absolutely necesary to change.some people say yes and others say just to change the filters and top it up.my car has 115000 miles.
M3 cecotto ultimate driving machine
darkchild
On my old auto M43 turd I changed the gearbox oil at 80K with no noticeable difference, good or bad.
Some say its not worth doing once you get past 100K, fresh oil can result in a whine from the box or make more apparent any minor issues that it has.
Andyboy
- Alpina Colada
What car is it?whiterhino wrote:my car has 115000 miles.
whiterhino
andyboy its a 328i.
Andyboy
- Alpina Colada
Depends what year it is. Very early ones from 1995 were still using Dexron 11 ATF which means oil/filter every inspection 11. Later ones from late '95 (E39 era) went to synthetic lifetime fluid. If you still have the service booket, it'll say but I've had a look at a 1996 E36 service book and it says the only model needing a gearbox oil change is the 325tds.
Either way, it's not a bad plan to drain the oil, drop the sump, replace the filter and refill with the correct oil - it's Esso-Mobil LT71141. Don't put Dexron in!
whiterhino
cheers andyboy the car is a 98 s reg.so the esso oil you reccomend is the one to go for.shall i have the oil changed completely or just change the filter and have it topped up with new stuff.
Andyboy
- Alpina Colada
Yup!whiterhino wrote: just change the filter and have it topped up with new stuff.
