Any thoughts on this E90 prob
rich318i
My mates got an E90 318i 07 plate. Took it to a Main dealer for an oil change now at 6000rpm the oil light comes on. Took it back to bmw they did the oil again and still doing it. Does that sound like the first signs oil pumped on it's way out ???
maxfield
Could be a faulty switch, maybe worth putting and oil pressure tester on there.
rich318i
just funny how they did the oil change it started to happen. New BM's are crap
Has he checked to oil level?
And this is in the wrong section.
rich318i
move to tech help mate if you can
rich318i
they have that silly push button oil check... no dipstick
Correct but has he used it to check the level? The oil level sensor is accurate.
It should be in other BMW chat and only a mod can move it.
rich318i
bss325i wrote:Correct but has he used it to check the level? The oil level sensor is accurate.
yeah was done at the main dealers. twice!!
Well if the oil pressure light is coming on at 6000 rpm and the oil level is correct then as maxfield says, an oil pressure check is needed.
gooseygander110
I've had it before where the end of the oil filter has broken of, bringing on the oil light. Unscrew the oil filter and make sure it's intact.
Gus
Gus
rich318i
cool dude thanks, did that happen on a E90 ?? just want to made it clear ta
gooseygander110
pretty sure it was ...yes
Andyboy
- Alpina Colada
That happens on Hengst filters that have been in there too long. This sounds more like an electrical fault - for an engine to have oil pressure at normal speeds but next to nothing at 6000 when the pump is going flat out doesn't make sense.
alpina123
these turds only rev to 5000?
No they dont.
alpina123
oh sorry barryi misread i thought it was diesel
