Hi
The oil filter housing gasket it gone on my mrs compact with m43 lump. Common problem apparently! Question is I'm doing it this week. It's a Paper gasket, question is should I whack on some gasket sealer too or just put on the gasket??
Thanks.
M43 oil filter housing.
kam325itouring
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
there are also some rubber seals iirc. Make sure everything is scrupously clean and just a smear of grease to hold everything in place. A straightforward but tedious job
