Compact Buyers guide
Post Sun Jul 08, 2012 7:30 pm
Looking at another compact as a daily, however want a half decent one this time
Whats should i mainly be looking out for with them. the car in questions is a 318ti in mtech flavour
Things i allready know, wankerd timing chain at 3500rpm, dodgey window mechs, rusty arches and wings.
I read 200 yellow ones were made is this true ?
Yes its yellow
Post Sun Jul 08, 2012 9:48 pm
Being ooop the grim north, rust is even more of an issue than down here. Have a good poke around the side skirts , flaking underseal at the rear of the sills and around the often missing jacking plugs can often lead to a hole :(
Dead A/C is never just gas. Airbag warning lights are common and now an MOT fail. Contrary to what the seller may tell you, a fuse won't fix it ! Rear wiper motors are often seized and the HRW is often moody due to lots of van action by previous council types ! Every compact I have ever owned or worked on has needed window attention at some stage so that is to be expected.
Make sure the rad has proper coolant and that the heater and the engine fan (late ones are electric)all work. The M44 is a lot less likely to think it is a kettle than a M43 but its not unknown.
Rear subframe mounts are a nasty job on a compact so have a good mooch around. Rear exhaust boxes are often toast.
Make sure it has a space saver spare and that the carrier hasn't gone all Titanic or awol.
It WILL need front wishbone bushes and outer balljoints but the good bits only cost £60 and a few hours swearing.
Like all old cars , they all have issues . But very few cars can be run as cheaply as these if you are handy. The bits are cheap and the scrapyards are full of E36s.
Luckily there are still loads of them around so just be patient and a nice one will appear :)
Post Sun Jul 08, 2012 9:52 pm
Cheers Pete, drove past the car in question tonight, and noticed the number plate ended in SLD
I will pay particular attention in the rust department being a scottish Turd :)
Am i right in thinking e30 wishbones fit these ?
mabz
Post Sun Jul 08, 2012 9:59 pm
cant believe your gonna look at a dakar yellow compact,you took the pee pee when i posted mine up a few years back :D its true they only made 200 it was to celebrate the end of the e36 production.i enjoyed mine nearly bought it back a couple of times as its been passed about like a dirty old porn mag,get some 17's on it straight away makes it drive so much nicer
Post Sun Jul 08, 2012 10:04 pm
i used to hate compacts with a passion :D
its all standard apart from nasty e46 wheels on it :(
bodger
Post Sun Jul 08, 2012 10:08 pm
wheres the corsa alex?
Post Sun Jul 08, 2012 10:37 pm
Boring me to death
Zerotonine
Post Mon Jul 09, 2012 12:29 pm
My old one had the cat rot out, so needed replacing, drivers electric window kept making a bid for freedom, rocker gasket was weeping, the rubber on the rear pop out windows like perishing where the doors meet it, cloth interior stitch comes undone at the slightest provacation.
All fairly minor stuff, I loved my compact. But mine was a nice rust free example.
Finally promoted to Regular! Only took 7 years...
Post Mon Jul 09, 2012 3:59 pm
twas a lemon, had yellow overspray all over the underseal underneith 8O and had wha looked a fooked shock at the back
Post Tue Jul 10, 2012 5:04 pm
I run a 318Ti M Sport Edition ( Agean blue) , a very nice piece of kit to run.
