Hi guys, hoping someone will know what causes it.
Always starts from cold with no issues
When warm it often doesn't start. Leave it 10 - 20 mins and try again and it fires straight into life.
Its had a new fuel pump in, but still the same
Any idea's welcome
Its a 2000 Model
Many thanx
Andy
530 Diesel Starting issues
Andy325i
irish320i
start with a code read if it shows nothing then on to a leak of check on the injectors if thats all good I would suspect a crank sensor. Its not a big deal if it is.
Regards
Regards
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
Andy325i
Thanx mate, will follow it up!
Would a crank sensor not show up in the fault codes?
Many thanx
Andy
Many thanx
Andy
