Compact gearbox
powelly
Post Sat Mar 10, 2012 12:32 pm
Does anyone no what gear oil to use in the compact, M43B19TU engine 1999 V reg, some places say it's ATF some say it's some BMW special stuff and I can't see anything on the gearbox it's self.
Image Le Mans Classic 2006
Post Sat Mar 10, 2012 7:12 pm
Depends what sticker it has on it. I had a 328i in a while ago that had the LT (lifetime) oil in it, if it has this I found the best stuff to replace it with is Redline MTF fully synthetic
powelly
Post Sat Mar 10, 2012 7:52 pm
Cheers. I'll have to get it up on the ramp at work and have a better look.
Andyboy
Alpina Colada
Post Sun Mar 11, 2012 12:29 pm
I've got a box from a 1999V Compact in mine. It has fresh ATF Dexron 11, and it's pretty rattly on idle when hot. I might have to drain it and put something else in.
Post Sun Mar 11, 2012 12:32 pm
Redline MTF, a mate put some in his rattly iS box and it stopped the rattle 8)
Andyboy
Alpina Colada
Post Sun Mar 11, 2012 12:44 pm
I was thinking more in terms of some EP80! I'll stick some in - it's cheap enough and it shouldn't be too baulky now the weather is warming up. I just looked at TIS and they recommend it for summer use.
Post Sun Mar 11, 2012 12:46 pm
Cheapskate :)
Andyboy
Alpina Colada
Post Sun Mar 11, 2012 12:59 pm
Every pound is a prisoner here!
powelly
Post Sun Mar 11, 2012 2:26 pm
This is just maintenance, no rattles at present, second gear is a bit whiney and It's a bit heavy when cold, to be expected from a 170k gearbox that's not had the easiest of lives.
