If there's anything you could change,
ah
about the original E30 design,what would it be.
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
BMWE30325
rust rust rust lol
harry_p
Yep, galvanised shell would have been a good improvement!
cheers,
harry
harry
Adjustable steering column for rake and reach please?
Oh and a quicker rack!
All of the above plus a centre arm rest that doesnt look like its from halfords!
harry_p
Maybe the engine swappers would like to have more room around the steering column / linkage.
A better rhd brake servo setup would be great allongside a quicker rack, the entire rhd conversion seems a bit half arsed.
cheers,
harry
harry
fixedwheelnut
Adjustable rear track & camber, without resorting to bushes
Accessible rear brake pipes without dropping the fuel tank
darkchild
Agreed! The standard steering rack is woeful.B7 wrote:Adjustable steering column for rake and reach please?
Cloggy Saint
i've never found the rack a problem, if the injection system on the 6 pots didn't fire 3 injectors at a time the economy of the M20 would no doubt be alot better as your not throwing 66% of the fuel away!
gooner1
- Out humping Reindeer
The Headlight performance during darkness.
pac1982
Better headlights, sort the rust issue, more engine choice, electric rear windows on coupes
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
mabz
16" bbs cross spokes staggered like the alpina's
HairyScreech
steering rack/column is easily sorted, rust can never truly be solved, head lights is a simple upgrade, when i m50 management mine ill do a full write up making that a nuts and bolts job.
4 stud is one of the issues thats not so easy to sort until someone solves that it limits our oem break and wheel options.
the rear end semi trailing arm design is dire, would love a proper multi link rear end.
e30kev
"has it got one of those hooks for hanging your jacket up?"
Yes.e30kev wrote:"has it got one of those hooks for hanging your jacket up?"
HairyScreech
iv got two, there on the grab handles for a touring/4 door.
e30kev
was just messing, I remembered the toyota avensis advert? where the guy gives his work mates a lift and they are really impressed
but have to try and fault it somehow and hence the phrase
pukar
e301988325i
The standard (non sport) gear box ratio's!
I said:
e30topless said:
lock the wife in there
HairyScreech
^^ 320 box boss.
i find mine is blowing hot after about 1 min or half a mile.
i wouldn't change a thing !
Duke137
I would like to change it so it looked more like a P reg clio
Split folding rear seats, quicker rack, better anti corrosion design.
TouringTash
As is.
Like most things in life, we love the faults as much as the rest, why should a car be different.
Edit
Its attraction by a certain type of knuckle dragger.
Edit
318i Touring
leeparkes
Rear lights lifting up with the tailgate on Tourings to give better access.
bmw9818
bss325i wrote:All of the above plus a centre arm rest that doesnt look like its from halfords!
mabz
they should have let stevie design it
.then they would be perfect
adit
go on Atul, treat your self for Christmas:pukar wrote:
also a small electric heater so that on cold winter mornings, hot air blows straight away to de-ice the car
http://www.ebay.co.uk/itm/BMW-3-12v-Car ... 35b6e896ac
i can even supply a bmw roundel to stick on it for er...authenticity
[quote="bss325i"]
pukar
not if i get a sticker on it first, then it will be genuine alpina and sell for 3x price...now that's just a hairdryer ady! i meant something a little more "installed". i remember seeing this option on a peugeot 306 gti6....basically, as soon as the car was switched on, hot air was available through the normal vents with no extra kit to be seen...i know its french, but it's still a good idea! i would have thought the scandinavians would have thought of it....adit wrote:go on Atul, treat your self for Christmas:pukar wrote:
split rear seats already mentioned would be on my list for sure
didn't foreign "motorsport" cabs have the option of staggered 15inch bbs'?
I've seen this on a E39 525d. Its called an Aux heater. In my E34 you can program the ventilation to come on when you set it on the OBC, but no heated.pukar wrote:un-crackable dash
powelly
The hideous pile of junk sunroof, what a crap idea and dare I say it BMW could have done with a lesson on corrosion protection from the French.
Le Mans Classic 2006
