are M43 heads prone to cracking?
just bought a nice 1994 518i (M43 engine) from a dealer about 25 miles from my house (with no warranty), it seemed a solid enough car and was driving beautifully until 5 miles from my house the top hose blew off and it dropped all the coolant. it seems that the plastic pipe on the rad had cracked and the remains of it were in the top hose. fortunately i spotted the temp going up and turned it off just before it got into the red.
i let it cool by the side of the road and my mate came to the rescue with a barrel of water. we topped it up and attempted to bleed it up a bit at the side of the road but it just kept blowing water out of the top of the filler neck as if the system was being pressurised.
i'm fairly sure this is headgasket failure or a cracked head. i need to know if the m43 heads are prone to cracking so i can decide what to do i.e. negotiating for some of my money back and keep the car or all of my money back and give the car back. it would be a shame if i had to give it back as it's a lovely car that drives a lot nicer than any of my other beemers. i'm capable of fixing it myself and would rather know it's been done properly myself than have them do it on the cheap (if they offer to fix it) i.e. not skim the head etc.
i called the dealer and he said bring it back so his guys can have a look at it; i'm taking it back to the dealer tomorrow.
also if anyone knows of any areas of the headgasket that are prone to failure that may be helpful.
E34 518i
alan1272
As you've literally just bought it from a dealer they have to offer some sort of warranty and either fix it or refund you. If you'd bought it privately you wouldnt have a leg to stand on.
I had cooling system issues with my last E36 I bought from a dealer - ended up costing them a genuine BMW radiator, Water pump and thermostat - which was probably all the profit they made on the car !
Let the dealer sort it out - less hassle for you and if they fix it they have to guarantee the work.
e30mtech
water pump mate, they come with a plastic blade fitted which ends up cracking and coming off the spindle, whole system pressurises cracks rad etc, 15 min- hour depending on skills to remove water pump and check, you'll prob find that the problem! had same problem with my m50, i also drive a 518 1994 as my daily driver,
when you buy a new pump make sure it a metal end one.
quick guide done on doing my m50 pump you will see what i mean bout the plastic finned pump
sure it same prob with the 1.8
http://forum.bmw5.co.uk/topic/42426-rep ... msearch__1
darkchild
M43s are lovely little donks but head gasket failure is their one problem area. BMW didn't fit them with a coolant level sensor. They're quite an easy fix though.
Andyboy
- Alpina Colada
There you go. Sale of Goods act be damned, you cannot guarantee a 15+ year old car for 5 minutes, never mind 3/6 months. I'm surprised a dealer even entertained it.alan1272 wrote: (with no warranty)
M43 heads rarely crack - a skim, gasket and bolts will sort it along with a pump and a used rad.
alan1272
If you're going to fix it yourself get a KWP pump from ECP - collect it in person and open the box before you leave the shop to make sure though.
alan1272
well i limped it back 20 miles with no problems. kept the revs low and made sure i didn't put it under much load, this makes me think that its going to be the head gasket as it had originally failed when under heavy load up a hill.
dealer was very apologetic and asked me to contact him tomorrow.
what i don't particularly want is for them to offer to fix it because for what i paid for the car, they'd be making a loss on doing a proper job of it, and that makes me think that they'll just bodge it to get it gone.
anyone know what an E34 goes for on the weighbridge so i can just offer him that much for it?
e30mtech
get bout 200-250 i reckon, maybe more.
alan1272
ok just been on the phone to them and they're claiming it was just the rad that was the problem. the mechanic spoke to me and said " the plastics degrade and thats why the pipe on the rad broke off." so they are replacing the rad.
i said to him i believe it was pressurising and he claimed there was just an air lock in the system.
anyone heard of this issue with the plastics on the radiators?
i find it slightly suspicious that it let go when going up a hill, i.e. under most load.
powelly
Well to be fair the plastic housings do break so I see no reason why the rad wouldn't suffer the same fate, I did an un neccesary head gasket replacement on my E36 316i compact (M43B19TU), it was a horrid thing to bleed, in the end I used a vacum filler and it got rid of the airlock first time, I also replaced the water pump again un neccesarily, the genuine plastic impeller pump with 160,000 miles on it was perfect.
Le Mans Classic 2006-
alan1272
jimbom30cab
- Tech 1 freak
great news, enjoy the car
