e21 ignition lock barrel
mark_i
Post Tue Aug 23, 2011 10:11 am
Hi Guys.
Anyone know how to remove the ignition barrel of an e21.
There is a small slot present, but not sure if removal is similar to an e30. I have the original key.
e21Jason
Post Tue Aug 23, 2011 12:21 pm
Yes need to drop the column really, but there is a small hole in the back of the barrel you can stick a pin through which will release the tumbler
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
mark_i
Post Tue Aug 23, 2011 10:02 pm
Thanks,OK, back of the barrel... i'll try that.
What position must the key be in before inserting the pin.
