the petrol guage has packed up on my 46 coupe,
it turns out it's the clocks that are facked and not the sender unit the guage is soldered into the speedo unit so i figured changing the clocks for a second hand unit is the best bet . are they coded to the car or will any E46 clocks work ?
E46 clocks,
i have a set!
irish320i
will you not end up with the spot on the mileage because it wont match the stored mileage in the lcm
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
fixedwheelnut
Yes and because they are coded to car some other features may misbehave, probably someone out there that can do it though.irish320i wrote:will you not end up with the spot on the mileage because it wont match the stored mileage in the lcm
leeparkes
Can the clocks be taken apart and just swap the fuel gauges over?
they are soldered onto the main board, I hate new cars !
give me a crumbly E30 any day at least they are simple to maintain !!
Morat
I just wish I could wield the MIG...
nickso
- Location: Go do that voodoo that you do so welllllllll!!
can you not just solder in a replacement gauge then? not difficult and certainly worth a go if the clocks are goosed anyway.e30topless wrote:they are soldered onto the main board, I hate new cars !
'88 e30 328i M52 track bint.
powelly
I think theres more than one set in stock moosh!!!!Simon13 wrote:i have a set!
Le Mans Classic 2006
