328I Compact build
powelly
As above, I am very seriously considering doing this to my compact in the not to distant, does anyone know what will required, I would imagine with a donor car the mechanical swap will be relativeley straight forward the issues I am more concerned with are the EWS and also potential ABS/ASC issues, the car is a V reg 316i (M43B19TU), I remember Kos had a 328 compact and it was very nice, also after borrowing Si's 328 touring for a couple of weeks I personally didn't think the fuel consumption was that crippling especially as most of my driving is motorway.
Le Mans Classic 2006-
Ant
- Retired Team Member
EWS 3 needs removing and a couple of wires moved to get the EWS 2 on the M52 loom working
compacts dont have a send/receive module between the ring antenna and EWS box, so thats what you need to add.
Easily done BTW
Mines staying M44B19
Easily done BTW
Email FTW
- Homo Hair
E36 Compact wont be EWS 3 will it?
Ant
last 4 I swapped to 6 cyls were dude.
Email FTW
- Homo Hair
Furry muff.. Didn't realise it saw the E36 era.
Not sure of the dates but the later cars did go to EWS3, I think its around 98 when they changed, same with the E39's you can get a 528i single vanos with EWS3
Andyboy
- Alpina Colada
EWS 3 is the one with the bigger white EWS module under the dash on the drivers side - it's basically an E46 set up. I've just broken a '99 1.9 Compact with this system.
leeparkes
My compact is iirc late 98 and it was EWS 3, as said its just a case of cutting EWS 3 out and grafting EWS 2 onto it. I do have a list somewhere but iirc you just match colour to colour from both modules.
You will need to shift all the main + wires from one side of the loom to the other too to connect to the battery.
You will be lucky to get the ASC in as the TB fouls the battery, i removed my ASC and the ABS still works fine.
Here's my swap if it helps, loads of pics and info in there.
http://www.e30zone.net/modules.php?name ... sc&start=0
leeparkes
This is what i was sent from a guy on E36coupe who has also done an M52 compact.
Danthe was a big help too
EWS 3 pin configuration (pin no. - colour - function)
1 - BLK - Ground
2 - RED/YEL - Fuse 31
3 - Auto only
4 - WHT/VIO - Diagnostic
5 - BLK - DME control unit
6 -
7 - BLK/YEL - Starter
8 - GRN/BLK - Ignition switch
9 - VIO/WHT - Fuse 45
10 - YEL/BLU - Toroidal coil
11 - YEL/BRN - Toroidal coil
12 -
13 - BLK/GRN - ZKE control unit
14 - GRN - DME control unit (immob. device)
15 - BLU/RED/YEL - Control unit, remote control
EWS 2 pin configuration (pin no. - colour - function)
1 - BLK/YEL - Starter
2 - WHT/VIO - Diagnostic
3 - GRN/BLK - Ignition
5 - RED/GRN - Fuse 31
6 -
7 - BRN - Ground
8 - BLK/GRN - ZKE
9 - Auto only
10 -
11 -
12 - BLK - Instrument cluster (engine speed input)
13 - BLU - Transmitter module
14 - BLU/RED/YEL - control unit, remote control
15 - BLK/GRN - obc
bigdoe
Kos
thankspowelly wrote:As above, I am very seriously considering doing this to my compact in the not to distant, does anyone know what will required, I would imagine with a donor car the mechanical swap will be relativeley straight forward the issues I am more concerned with are the EWS and also potential ABS/ASC issues, the car is a V reg 316i (M43B19TU), I remember Kos had a 328 compact and it was very nice, also after borrowing Si's 328 touring for a couple of weeks I personally didn't think the fuel consumption was that crippling especially as most of my driving is motorway.
the best bet is to buy a complete donor car, you will need other things like a 6 pot ARB, Rad etc
finally, an e30 medium case LSD with a ratio about 3.07 will be ideal. a 3.25 like can be a bit buzzy and harm your MPG. your existing diff is small case one and it will be ok up to a point. and hard driving and it will expire. its probably a short ratio of about 3.38, thats what was on my ti. too short on motorway runs
ABS should not be an issue, and as for ASC, bin it. you wont need it and its for poofs and i'm sure you'll have an LSD
when you fit an e30 diff, you can use the existing out put flanges which mate up to the with the shafts. i;ve had no issues despite some peoples "concerns". if you use the e30 flanges, you will need e30 shafts and need to space out the ABS sensor to avoid it hitting anything
as for ews, dan sorted mine out
scott180gtb
I have been thinking about this type of conversion for a track car. I will keep a lookout for your build thread
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
leeparkes
Also you will need a 6 pot instrument cluster,
also you will need to work out a rear silencer, nothing is an exact fit apart from Z3 2.8 and even then it still needs chopping to make shorter (or longer)
centre section fits perfect
powelly
Interesting reading guys, thanks for the input. It's definatley a conversion I want to do, such a shame BMW never made one. Some thoughts on the exhaust, we know in europe they did have a 323i 6 cylinder compact, would it not be simpler to get a one of these or would it not mate up to a 2.8, also concerning the engine, am I right in thinking you could build an engine using the M50 cast iron block but with the M52 internals and head etc, if my understanding is correct this would make a US spec engine.
Andyboy
- Alpina Colada
Post 1998 316i 1.9's use a 3.23 diff which is okay - 70 mph is 3000 rpm in 5th as opposed to 3500 with the original 3.45.Kos wrote: finally, an e30 medium case LSD with a ratio about 3.07 will be ideal. a 3.25 like can be a bit buzzy and harm your MPG. your existing diff is small case one and it will be ok up to a point. and hard driving and it will expire. its probably a short ratio of about 3.38, thats what was on my ti. too short on motorway runs
I have an instrument cluster from an E36 328i in my garage doing nothing, it came from the donor car I raped for my M52 lump, I think it was showing about 139k on the odometer.
On the exhaust front, it will probably be best to butcher a stock 328 system as they seem to flow pretty well and probably just need 6" chopping from the length of the centre section pipes.
In E36 circles, the lads with 323i's often upgrade their exhausts to the 2.8 version as they are larger diameter pipes, so I would avoid using the 323 setup as it may be restrictive.
leeparkes
The rear box is too long to fit under there, it hits the driveshaft. You could bodge one on but it would have to sit low.E30BeemerLad wrote:On the exhaust front, it will probably be best to butcher a stock 328 system as they seem to flow pretty well and probably just need 6" chopping from the length of the centre section pipes.
E46 boxes are smaller in length and use 50mm pipes so may be a possibility, iirc the box cant be no longer than 50cm.
