I got this weird problem with a E38 where hot air constantly comes front the windscreen demister which cant be stopped.
Anyone familiar with this problem?
EDIT: Sorted kind of. Only does it with auto enabled on the climate control. But does not with the face setting enabled, good enough for me.
E38 hot air from demister
MJJ_ZX6RR
On my E32, that is normally a sign that the underbonnet heater valve has siezed open. There is two valves in a single valve body, one for driver, one for passenger side.
You would have heat pouring out of the footwell vent on that side though too, regardless of where the climate control temperature is set.
Martin.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
