m47 diesel issues
blitz877
AKA ajm-e30
Sun May 22, 2011 8:24 pm
hey all, any of you no anything about the m47 e46 diesel engine? having a few "issues" with it
thanks ad
Dave_M3
Sun May 22, 2011 8:32 pm
What sort of "issues" :)
blitz877
AKA ajm-e30
Sun May 22, 2011 8:37 pm
ok, bought the car a month ago and it needed a flywheel which was replaced at my work and everything was fine until i drove it into work the next day, on the way to work a rather loud "knocking" noise coming from the engine, its not a diesel knock as far as i no, ive had the inlet side apart but cant find anything out of the ordinary................im now listening to any thoughts ppl might have
cheers
Ajsingh
Sun May 22, 2011 11:46 pm
If its a 320d then id would take off the inlet manifold and inspect the swirl flaps as these perish and can fall into the cyclinder and cause engine failure.. This is a common problem with this engine, if the swirl flaps are ok or not, id replace the inlet manifold with a new one as the new one is modified... Also change the engine oil breather, thats sits on the rocker cover as this can get blocked and cause issues and potential oil leaks from under the inlet manifold...
E30 Crazy!
Dave_M3
Mon May 23, 2011 2:19 am
Ajsingh wrote:If its a 320d then id would take off the inlet manifold and inspect the swirl flaps as these perish and can fall into the cyclinder and cause engine failure.. This is a common problem with this engine, if the swirl flaps are ok or not, id replace the inlet manifold with a new one as the new one is modified... Also change the engine oil breather, thats sits on the rocker cover as this can get blocked and cause issues and potential oil leaks from under the inlet manifold...
No need to replace the whole inlet manifold!
Just remove the flaps and fit some blanking plugs instead.
The EGR valve is a prick for getting blocked up alright causing it to run shite but wouldn't cause knocking.
blitz877
AKA ajm-e30
Mon May 23, 2011 8:39 am
its not got swirl flaps as its the earlier engine, its already got the modified oil breather and ive cleaned the egr too, its just so annoying as i dont no whats wrong with it :x
Morat
Mon May 23, 2011 9:54 am
Wrong forum dude, moved for you :)
blitz877
AKA ajm-e30
Mon May 23, 2011 4:26 pm
Morat wrote:Wrong forum dude, moved for you :)
ooops sorry :D
blitz877
AKA ajm-e30
Fri May 27, 2011 9:29 am
ok so ive narrowed it down to either the pump or injectors, im sending the injectors off to be balanced so that may shed some light if it those :?
