e90 with traction control not working
dbexportgold
Hi guys just had a m8 e90 320 diesel bought as a write off frontal,repair it just got it going just called me hasent got traction control has an abs light on hes dash? thanks
The Egyptian spec ones all do that
irish320i
Maybe something as simple as wheel alignment off or steering angle sensor could be anything without any fault codes
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
BadDave
Get the codes read 1st and then get them cleared and get them read again.
It'll most likely be an ABS sensor,trigger ring,damaged sensor wire or dry joint on the pump circuitry. That's the main suspects.
