My new BMW E36 few questions
robbo86
Ok, I have picked up my old mans 328 e36 four door in Samoa blue having flogged my e34. It's about 105k miles and a few little niggles need sorting. Will post some pictures up soon, when I get on the computer, mrs86 is essay writing ATM.
Anyway, my first question is this: it has one of the sigma 3t alarms and the siren internal battery went flat, meaning it no longer sounds. Does anyone know how to open the siren to replace it? I had a breif look in the dark but couldn't find the answer.
Secondly, the passenger door does not lock or unlock off the central locking 99% of the time, there is the odd occasions when it does. Is this going to be a new relay or solenoid?
Thirdly, what should a new backbox cost me. The owner before my dad welded some chrome trims on the end of the tailpipe. They look nice but are rusted and I think beyond saving. I reckon I should replace the box and get the BMW chrome tailpipe trims!
I will post up more questions as and when I discover the wee small jobs I want to do.
TIA
TIA
Simon
You would be better looking for a 2nd hand standard back box, these systems last ages, and finding a 2nd hand one should be simple, they go for peanuts on e-bay.
New one is going to be big bucks!
Central locking fault should be a simple actuator fault.
robbo86
Thanks. Was thinking last night, it's relatively well specced 18 button obc etc but no leather! Can you guys think of any other suitable retrofit oem goodness (leather being the obvious one).
Any question I have is, would changing my head lights cause my check control on the obc to come on saying they are out. I know you can get some kits with the CANBUS stuff on it, but does this apply to mine? Also, since swapping the rear lights for a clear indicator set, the OBC says tail light failure in spite of the fact I know they all work? Lastly, there are a couple of bulbs out on the spoiler brake light. Are these easy to replace?
Simon
Loads of nice mods can be done to E36's, plenty of retro fit stuff too.
Auto dimming interior mirror
Footwell lights
Cruise control
Rear electric windows (2 door and 4 door)
Just a little start for you.
E36 is too early for Canbus.
Have you fitted a HID kit?
Some E36's are fitted with a CCM, did the rear lights come from a car without the OBC?
Footwell lights
Cruise control
town325i
Ive just bought a e36 328i in cosmos black nice colour it is a moordoor but when you hit the loud peddle it dont half shift down the road it has air con front electric windows and thats about it oh its on coilovers as well
you all need leathers, centre arms rests and parking sensors!
town325i
Parking sensors are for gays who cant drive
nickso
- Location: Go do that voodoo that you do so welllllllll!!
i have centre armrests for sale.
'88 e30 328i M52 track bint.
Tow bars are for real men
If anyone wants an executive black leather arm rest I can hit you up
robbo86
Can you do me a cheap excellent quality four door leather set? No? Oh well.
Lights may have come from a motor without an OBC, I'm not sure, they were in a scrapper, what's ccm? Not fitted HIDs yet. Got the leccy windows all round. Don't think I can do the auto dim mirror as it's windscreen mounted, prepared to be corrected mind. I wouldn't mind reverse park sensors (provided the oem set can be got easily). Prepared for the abuse. My response? Ram it!
Never knew these had footwell lights. It's a little sad but I am looking on egay for the switched rear lights as mine aren't. Are these a straight swap?
robbo86
Oh yeah, I got the centre arm rest to
Baurluvva
I've got a std 328i rear box available pm for details.
The rear view should twist vertically and then pop off same as e34 (i have one of these too)
robbo86
Yeah, but it still doesn't mean I can fit the autodim mirror!
robbo86
Any idea on the tail-lights error? Also today I unbolted the seats to have a proper vacuum throughout the car. Upon putting them back (making sure I plugged the deeley in that is under the passenger seat) but when I start her up the airbag light stays on for a couple of minutes before going out. Any ideas? Also had the rear seat base up to vacuum under that but did not disturb at all the little box under that for the airbag.
robbo86
Any ideas on the lights error message, wether HIDs will cause the error message to come up and the airbag light coming on?
Ziggy
My E36 has a windscreen mounted auto-dim mirror
I would guess that unplugging the pretensioners with the battery connected has had the same effect as unplugging the instrument cluster would have done - ie it's raised a fault code which you'll need to clear in order for the airbag light to stop warning you about it.
aj_mckay
What Ziggy says is right, if you unplugged the seatbelt pre-tensioners under the seats while the battery was connected it will cause the light on the dash to come on when you start the car.
You'll either need to find someone who has the reset tool or pay a visit to your local dealer/independent BMW specialist to clear it. Always disconnect the battery in advance of disconnecting pre-tensioners and airbags etc.
harry_p
i've got hids on my '96 e36 and they don't cause an error.
(very) occasionally one will fail to fire up when turned on, and i get an error message, so it all still works.
cheers,
harry
harry
robbo86
Anyone know how one would retrofit the auto dim mirror
aj_mckay
Yep, you just need to tap into the power to the elec sunroof switch or similar.
One of the guys on the e36coupe forum (you should check that place out - will have most if not all the answers you need) did this retro-fit and included a brief write up in his journal (HERE).
Ziggy
Just a quick warning for you - auto-dim mirrors ain't all that! I expect you've tried one before but if you haven't, I'd recommend it before you go to any effort to 'upgrade'...
aj_mckay
They're a little weird at first but once you get used to them they're quite good IMO.
My car has tinted windows and sometimes I find that when the mirror dims it's a little too dim but I think without the tinted windows it'd be spot on. All a matter of preference.
Ziggy
It's the colour that annoys me slightly... not the end of the world by any means, but then neither is switching it manually!
jessy
hello everyone...
ziggy is right...
ziggy is right...
aj_mckay
Thank God you're here to clear that up for us! Thanks!jessy wrote:hello everyone...
ziggy is right...
harry_p
Well I like the autodimming mirror, really miss it when in a car without one tbh
cheers,
harry
harry
robbo86
I just like toys though so....
Ziggy
I don't dislike it overall, just thought I'd point out that (IMO) they aren't perfect.
If you pull the headlining down a bit the plug for the mirror is usually tucked up with other wires somewhere. Needs to be an utter poverty spec shitter to not have the plug hiding away!
Simon
How much do the mirrors sell for? Got a couple gathering dust..
robbo86
Pennies simon.... Might as well send me one and pay for my postage to boot. But in seriousness, if your selling one?
Simon
I will throw it in the post for a tenner if you like?
robbo86
Sounds good. Pm me a paypal address.
fingerman
I also have one of these auto dimming mirrors on ebay at the mo
Previously owned loads of old E30s, E34s, a few E36s, E32s, E39s and an E38.
Currently in a diesel Audi - miss me old E30's....
