How does 1 reset the service lights on an e36 323i using a jumper wire?
I've done this on my e30 when it was m20 but I imagine the pin numbers would be different.
A 2 door e30 with 8 cylinders, what could be better
caution, i read somewhere that jumpering the contacts can damage the ECU, it was recommended that you use a wire with a resistor in series to limit the voltage.
if someone with the peek tool can measure the resistance across the terminals with the tool service set switch depressed would be helpful.
