Hi there, was driving my e34 to work earlier sailing along quite nicely, when all of a sudden, then engine revs dropped and and the engine actually died, it was only becuase I still had forward momentum did the car rollstart itself and I was able to pull inot a local petrol station. I drove away and it was rough for a few hundred metres, I switched the old girl off. Started it up after a minute or so, revved it up and it was fine. As I drove home again it was fine, all the way until I was home when as I came to pull up to my house it started struggling, as if starved of petrol, but theres enough in there.
Its a manual m20b25. Ideas people?
E34 stutter
robbo86
Sounds like a loose electrical connection, affecting either ignition coil or the ECU. I'd check the engine earth strap and main ignition feed to the ECU and coil, then the DME relay and go from there.
robbo86
Cheers Maurice. Ill have a look. May be a dumb question, but what is the DME relay?
That's the one that feeds the ignition-switched live +12V to the ECU. The "System (main) relay" in this pic:
It is located under the large rectangular plastic cover on the driver's side, adjacent to the bulkhead.
robbo86
Cheers mate!
bmpaul
i would check the cam sensor and the crank sensor as those symptoms sound the same as mine and that was what it was
E39 530d M-sport- quite nippy
