Bought an E36, whats worth changing?
ross_jsy
Post Sun Nov 28, 2010 11:12 pm
Bought an E36 316i as a daily drive through the winter thats a bit rough around the edges but a nice runner with a few luxuries.
Problem is the gear shift is like stirring a bowl of soup. Since the bits need replacing anyway, can I do a z3 shifter conversion like on the e30?
Also the hand brake isn't working, anything common to look out for?
Kos
Post Sun Nov 28, 2010 11:14 pm
yes you can fit the Z3 lever
h/brake probably just needs adjusting
just go over it and check all the usual things, same principles apply to all cars
generally e36's are pretty robust things
leeparkes
Post Sun Nov 28, 2010 11:15 pm
ross_jsy wrote:Problem is the gear shift is like stirring a bowl of soup. Since the bits need replacing anyway, can I do a z3 shifter conversion like on the e30?
Yes, im using a Z3 1.9 shifter in the compact
dazleeds
old skool raver
old skool raver
Post Sun Nov 28, 2010 11:17 pm
had a short in my old 320 e36
lovely tight n smooth change :cool:
www.oldskoolfantasy.co.uk
Andyboy
Alpina Colada
Post Sun Nov 28, 2010 11:25 pm
ross_jsy wrote:Also the hand brake isn't working, anything common to look out for?
You'll find the rear shoes will need looking at as they've got rear drums. I'd expect to find a rusty siezed quadrant where the handbrake cable comes into the back plate. Free those off, adjust the shoes and lastly take up the slack at the lever end.
robbo86
Post Sun Nov 28, 2010 11:28 pm
What about on a 328?
Kos
Post Sun Nov 28, 2010 11:32 pm
there selector rod may need bending
i'm using a zm lever on my 2.8 box, but it getting binned for a Rogue engineering SSK at some stage
ross_jsy
Post Sun Nov 28, 2010 11:36 pm
Thanks guys and cheers Andy, will give that a go.
Quite excited about smoking round in it :)
ross_jsy
Post Sun Nov 28, 2010 11:40 pm
Kos wrote:there selector rod may need bending
Could ya let me know what you think of that ssk when you have it?
I am looking at the AKG shift kit.
Kos
Post Sun Nov 28, 2010 11:48 pm
i've had one before, it is a great bit of kit.
they've got a few left on the shelf as they made a short production run of 10 kits recently. the only thing they could improve on is by making the selector rod a double shear one like the UUC item and AKG ones
i am also considering getting an e30 DTM style shifter like the AKG one
adit
Post Tue Nov 30, 2010 3:47 pm
ross_jsy wrote:Bought an E36, whats worth changing?
the 6 for a 0 :snigger:
only joking Ross, i've had a couple myself as run-arounds. they were ok really
[quote="bss325i"]
ross_jsy
Post Wed Dec 01, 2010 12:16 am
Hehe didn't fancy an e30 through winter.
Been cruising about in it today, quite enjoying it tbh. Makes a change from the fiesta turd I have been driving about in.
Anyone know what size tyres motorsports take? Just the fronts, got new back shoes on.
Andy325i
Post Wed Dec 01, 2010 12:48 am
235 all round or staggered are 225 fronts and 255 rears iirc
ross_jsy
Post Wed Dec 01, 2010 12:54 am
They are the staggered set.
Cheers :D
Andy325i
Post Wed Dec 01, 2010 12:55 am
Sorry, 225/45/17 for the front and 245/40/17" for the rears
Hth
Andy
