Replace Ally Block With Iron?
StuBeeDoo
Post Sat Nov 27, 2010 10:24 am
I'm not planning on doing this, but I'm curious.
Supposing you had an M52B28 with stripped threads. Could you use everything bar the block with an M50B25 block?
m_jermyn
Post Sat Nov 27, 2010 10:32 am
So use the m20 block with all the m52 bits?
StuBeeDoo
Post Sat Nov 27, 2010 10:36 am
m_jermyn wrote:So use the m20 block with all the m52 bits?
No, M50! :D
leeparkes
Post Sat Nov 27, 2010 11:15 am
Yes, M52 crank rods & pistons can be built into an iron block M50.
BadDave
Post Sat Nov 27, 2010 11:41 am
leeparkes wrote:Yes, M52 crank rods & pistons can be built into an iron block M50.
US spec E36 M3's were built like that, so too are the 3.0/3.2/3.3L Alpina's
StuBeeDoo
Post Sat Nov 27, 2010 3:06 pm
Thanks. That answers my question nicely.
leeparkes
Post Sat Nov 27, 2010 3:09 pm
I have a 2.8 crank, rods, pistons here if your interested Stu.
StuBeeDoo
Post Sat Nov 27, 2010 3:14 pm
leeparkes wrote:I have a 2.8 crank, rods, pistons here if your interested Stu.
StuBeeDoo wrote:I'm not planning on doing this, but I'm curious.
Tempting Lee, especially as I have a crazy experiment I'd like to do with an M20 block and 'head which involves the parts you're offering. Trouble is I've already thrown the thick end of £3.5k at engine replacements/rebuilds in the last 2 years. Wor Lass would go light if I did another one now.
**BANNED**
Post Sat Nov 27, 2010 5:12 pm
DanThe has done this,and Dezzy's build is based around an iron block.
Wieght saving is minimal,the difference in the blocks is only about 20kg.
I keep thinking about a 2.8 for the touring,thinking that a hybred M52 is the way to go.
Youth is wasted on the young.
