Guys,
im going to have a look at a 1998 525tds touring in the morning.....the only problem with the car that ive been told is that the heaters work ok but the blowers dont work!!!!does anyone know what the fault could be????fuse maybe(if so which number??),,,
Also is there anything else that i should check on the car??
CHEERS GUYS...
525 tds touring...blowers,,,
The most common cause of a non functioning E39 blower is the heater resistor which is located on the right hand side of the heater box under the dash.
PS The heater resistor on an E30 M3 is located either on the LHS of the heater box or attached to the heater fan if the car has aircon.........
burtcocain
Thankyou for the info...............how do i remove the heater box from the dash????
regards.....
regards.....
Andyboy
- Alpina Colada
Don't think I can be arsed explaining how to fix E39 blowers if this is another shaggy dog story..................
Morat
Google "Hedgehog resistor" and you should find a few guides.
burtcocain
Andyboy,
Thanks for the info.....
just for the record...this isnt "another shaggy dog story"and i have NEVER told one!!!
ITS UP TO YOU IF YOU WANT TO BELIEVE ME OR NOT!!
HairyScreech
dude seriously, just put a few pictures up and clear your name,other wise its only going to follow you about like a bad smell.
Andyboy
- Alpina Colada
burtcocain wrote:Andyboy,
Not!
Andyboy
- Alpina Colada
So, did you buy this imaginary 525tds then, or was it yet more bullshit?
Hmmm, I'll take a wild guess................no photos?
