e46 330ci no reverse
TopSod
Post Tue Nov 23, 2010 5:43 pm
A bit of advice needed please!
When I tried to reverse my car earlier, it will only move under its own power, by which I mean I select reverse and the car starts to move, only a little though. As soon as I put power on the accelerator the car just revs. If the car is on an incline there isn't enough power for it to reverse on its own.
When I say reverse under its own power, I'm assuming it is on level ground, it looked it by eye but might not have been.
Reverse worked fine 1/2 hr earlier leaving work followed by 25 minutes on the M6 going home.
It seems to be fine in drive, but I did think it was maybe a little hesitant but maybe I'm just imagining that because of the reverse problem, I'm not sure.
Any ideas?
Edit: Its an SSG box
Andyboy
Alpina Colada
Post Tue Nov 23, 2010 11:04 pm
SSG - that's the Italian Magneti Marelli (Alfa Selespeed) system by another name. A f*cking disaster waiting to happen sadly. It's basically a standard manual gearbox and clutch but with a computer controlled hydraulic ram for the gearchange and another for the clutch slave cylinder.
My best guess is the control unit's packed up and/or the hydraulic actuator has gone tits up and won't re-engage the clutch in reverse. However, they can be converted to manual. BMW dealers might not be much help but they may be able to read the fault codes.
TopSod
Post Thu Nov 25, 2010 9:17 am
I was in it last night and its strange, when I put it in reverse the back end goes down as though it has engaged, but then doesn't do anything. I've got a BMW technician coming to have a look tomorrow so fingers crossed he has a better idea.
You are right though, they're not the best. I did a bit of googling and there are a shed load of lawsuits on the go for exactly the same problem.
